2017 CVO LIMITED Infotainment Information
I do a lot of embedded programming. RTOS/ WinCE/Android/iOS Some CanBus work in the poultry plant controllers. No QNX. I now work in Embarcadero's FireMonkey. It uses a Delphi IDE and Pascal but compiles to the OS native language. No Run times.
Been to HK's site. They have some SDKs but I didn't download anything. I much prefer an API.
I used to hack the android releases. Someone would always find an exploit. Usually someone has an inside friend that throws them a bone.
The sad thing is that some of the best ideas have come from us ROM cookers. We would add all kinds of things that users wanted and the next thing you know, it is in the next android release. Why have 50 programmers work on your project when you can have 50,000?
If anyone has a cracked ROM for the 6.5, i'd much appreciate it.
I opened the ISO and snooped around. Does not look to promising.
Here is the Jenkins manifest
Version 1.22.0.1
Built by jenkins_FH on Fri 10/13/2017 at 16:12:53.48 on HIFHWSJENKINS01
Variant 'PREM_NA'
Name Version Path
Accellion_AAA 1.0.0 Mid_Common.packages.mainproc.thirdparty.accellion_ AAA.trunk
active-partition 1.0.0 Harley.isys.omap.active-partition.trunk
antiReadDisturb 0.0.1 Mid_Common.packages.mainproc.harman.antiReadDistur ber.trunk
asextensionclasses 1.0.0 Mid_Common.packages.mainproc.harman.ASExtensionCla sses.trunk
asppsextensiondll 1.0.0 Harley.isys.omap.libase-pps
audioCtrlSvc 1.3.9 Harley.isys.omap.audioCtrlSvc_new.trunk
authenticationService 0.0.2 Mid_Common.sandbox.users.bsetter.packages.authenti cationService.trunk
boot-mode 1.0.1 Harley.isys.omap.boot-mode.trunk
bsp 1.0.22 Harley.isys.omap.bsp.trunk
BTClockSet 1.0.0 Harley.isys.omap.BTClockSet.trunk
buildtools 11.5.0 Mid_Common.packages.mainproc.harman.buildtools.tru nk
cbSvc 1.3.4 Harley.isys.omap.cbSvc.trunk
clear-screen 1.0.0 Harley.isys.omap.clear-screen.trunk
Clock_Generator 1.0.0 Harley.isys.clock.trunk
Common_Simple_Handsfree Jan-31-2013 Harley.isys.omap.simple_handsfree_standard.trunk
ContactBackup 1.0 Mid_Common.packages.mainproc.harman.ContactBackup. trunk
dbServer 1.0.0 Harley.isys.omap.dbAvail.trunk
dbservice 1.0.0 Mid_Common.packages.mainproc.harman.dbservice.trun k
dbus 1.2.7 Mid_Common.packages.mainproc.thirdparty.dbus.trunk
dbus-c++-async 1.0.0 Mid_Common.packages.mainproc.thirdparty.dbus-c++-async.trunk
DbusTraceMonitor 2.0.2 Mid_Common.packages.mainproc.thirdparty.DbusTraceM onitor.trunk
dev-gpio 1.3.0 Mid_Common.packages.mainproc.harman.dev-gpio.trunk
dev-ipc 2.3.0 Mid_Common.packages.mainproc.harman.dev-ipc.trunk
dev-memory 0.6.0 Mid_Common.packages.mainproc.harman.dev-memory.trunk
dev-mmap 1.5.0 Mid_Common.packages.mainproc.harman.dev-mmap.trunk
dev-sdio 1.0.7 Harley.isys.omap.dev-sdio.trunk
devc-ditto 0.0.1 Mid_Common.packages.mainproc.harman.devc-ditto.trunk
eqToolSvc 1.1.5 Harley.isys.omap.eqToolSvc.trunk
expat 2.0.1 Mid_Common.packages.mainproc.thirdparty.expat.trun k
ExternalAmpSvc 1.0.14 Harley.isys.omap.ExternalAmpSvc.trunk
faceplate 1.0.37 Harley.isys.omap.faceplate.trunk
fonts 1.1.1 Mid_Common.packages.mainproc.harman.fonts.trunk
fsService 1.30 Mid_Common.packages.mainproc.harman.fsService.trun k
fwcommon 2.1.0 Mid_Common.packages.mainproc.harman.fwcommon.trunk
gf-calib 1.1.0 Harley.isys.omap.gf-calib.trunk
harley-rot-fixer 0.7.0 Harley.isys.omap.harley_rot_fixer.trunk
Harley_ISYS_base_eqs 2.2.1 Harley.isys.omap.Harley_ISYS_base_eqs.trunk
HarleyFC-Premium 12293A Harley Prem Harley.isys.frontcontroller.trunk.premium
HarleyFC-Standard 12492A Harley Std Harley.isys.frontcontroller.trunk.standard
HarleyIOC app 2.21.4 - bolo 1.4.6 Harley.isys.ioc.trunk
HarleyManager 1.0.0 Harley.isys.omap.sysConfig.trunk
harleyManager_new 17.4.0 Harley.isys.omap.harleyManager_new.trunk
hbcifs 1.0.3 Mid_Common.packages.mainproc.harman.hbcifs.trunk
HMI 1.0.463 Harley.isys.omap.hmi.trunk
hmi_suite 0.6.0 Mid_Common.packages.mainproc.qnx.hmi_suite.trunk
imageChecksumUtility 0.1.0 Mid_Common.packages.mainproc.harman.imageChecksumU tility.trunk
infotainmentCANSvc 1.2.0 Harley.isys.omap.infotainmentCANSvc.trunk
io-audio_utils 1.0.5 Mid_Common.packages.mainproc.harman.io-audio_utils.trunk
ioc-boot-mode 1.0 Harley.isys.omap.persistencyWriteThrough.trunk
iocInterface 1.0.20 Harley.isys.omap.iocInterface.trunk
ipc-extdll 1.0.19 Mid_Common.packages.mainproc.harman.IpcExtDll.trun k
jsoncpp 1.5.1 Mid_Common.packages.mainproc.thirdparty.jsoncpp.tr unk
KbdMouseExtDLL 1.0.2 Harley.isys.omap.KbdMouseExtDLL.trunk
libasound-neon 2.0.0 Mid_Common.packages.mainproc.qnx.libasound.trunk
libeeprom 1.2.0 Mid_Common.packages.mainproc.harman.libeeprom.trun k
ListControl 1.2.1 Mid_Common.packages.mainproc.harman.flash.utils.Li stControl
lua 1.22.1 Mid_Common.packages.mainproc.harman.lua.trunk
mediaservice_mme 2017.W38.R01 Mid_Common.packages.mainproc.harman.mediaservice_m me.trunk
memifs2 1.2.9 Mid_Common.packages.mainproc.harman.memifs2.trunk
mictest 1.0.4 Mid_Common.packages.mainproc.harman.mictest.trunk
multicore 1.0.2 Mid_Common.packages.mainproc.harman.multicore.trun k
nav 280 Mid_Common.packages.mainproc.harman.nav.trunk
NavService 1.7.15 Harley.isys.omap.hmi.flash.nav.navservice
ndr 11.07.2013 Mid_Common.packages.mainproc.harman.ndr.trunk
onOff 1.0.76 Harley.isys.omap.onOff.trunk
persistency_mgr 3.0.4 Mid_Common.packages.mainproc.harman.persistency_mg r.trunk
poco 1.3.6 Mid_Common.packages.mainproc.thirdparty.poco.trunk
QNX Composition Manager 0.2.0 Mid_Common.packages.mainproc.qnx.composition_manag er.trunk
QNX MME 20.26.50 Mid_Common.packages.mainproc.qnx.mme.trunk
QNX650 1.4.13 Mid_Common.packages.mainproc.qnx.qnx650.trunk
routeStartService 00.00.01 Harley.isys.omap.routeStartService.trunk
ScreenCapture 1.1.0 Harley.isys.omap.ScreenCapture.trunk
service-monitor 1.1.0 Mid_Common.packages.mainproc.harman.service-monitor.trunk
set-boot-mode 1.0.1 Harley.isys.omap.set-boot-mode.trunk
set-ifs-size 1.0.1 Harley.isys.omap.set-ifs-size.trunk
set-partition 1.0.1 Harley.isys.omap.set-partition.trunk
SetDisplayBrightness 1.0.1 Harley.isys.omap.SetDisplayBrightness.trunk
sgx 0.12.0 Mid_Common.packages.mainproc.qnx.sgx.trunk
SimpleHandsFree 1.1.2 Harley.isys.omap.SimpleHandsFree.trunk
SlogExtDll 1.0.0 Mid_Common.packages.mainproc.harman.SlogExtDll.tru nk
speech_service RL_Harley_LLR_Delivery_2014_01_27 Harley.isys.omap.speech_service_standard.trunk
speech_service premium RL_Harley_HLR_Delivery_2013_12_17 Harley.isys.omap.speech_service_premium.trunk
splash-movie 1.6.0 Harley.isys.omap.splash-movie.trunk
splash-screen 0.8.0 Mid_Common.packages.mainproc.harman.splash-screen.trunk
Spot Tools 1.2.0 Mid_Common.packages.mainproc.harman.spottools.trun k
svcipc 1.0.11 Mid_Common.packages.mainproc.harman.svcipc.trunk
svcIpcCPP 2.0.0 Mid_Common.packages.mainproc.harman.svcIpcCPP.trun k
swdl-utils 0.0.2 Mid_Common.sandbox.users.kfurge.packages.swdl-utils.trunk
SWDLService 1.0.32 Harley.isys.omap.SWDLService.trunk
sxm_ws_alerts_db 1.0.0 Mid_Common.packages.mainproc.harman.sxm_ws_alerts_ db.trunk
tonetest 1.0.5 Mid_Common.packages.mainproc.harman.tonetest.trunk
TraceExtDLL 1.0.9 Mid_Common.packages.mainproc.harman.TraceExtDll.tr unk
tuner 12.07 Mid_Common.packages.mainproc.harman.tuner.trunk
UDS 4.65 Harley.isys.omap.diagnostics.trunk
uispeech_service 2017.W38.R01 Mid_Common.packages.mainproc.harman.uispeech_servi ce.trunk
UsbMonitor 1.0.0 Harley.isys.omap.UsbMonitor.trunk
vehicleCAN 1.0.31 Harley.isys.omap.vehicleCAN.trunk
wimSvc 1.4.5 Harley.isys.omap.wimSvc.trunk
xmApp 2.22.19 Mid_Common.packages.mainproc.harman.xmApp.trunk
XMAppTest 1.0.0 Harley.isys.omap.xmAppTest.trunk
XMInit 1.0.0 Harley.isys.omap.XMInit.trunk
XMShutdown 1.0.0 Harley.isys.omap.XMShutdown.trunk
Unknown Unknown Mid_Common : Missing manifest
Unknown Unknown Mid_Common.packages.mainproc.harman.bluetooth.trun k : Missing manifest
Unknown Unknown Mid_Common.packages.mainproc.harman.dbservice_qdb. trunk : Missing manifest
Unknown Unknown Mid_Common.packages.mainproc.harman.XMUpdate.trunk : Missing manifest
Unknown Unknown Mid_Common.sandbox.users.amckewan.lua.media.protot ype : Missing manifest
If I poked around long enough, I could probably make a few changes. I might even be able to defeat the MD5 checks. But all the good stuff is in the binaries.
This is an ARMv7 machine so it is a 32bit word.
Blackberry has some pretty good dev tools but without the source, you are SOL. I grabbed the QNXS neutrino but it'll take a better programmer than me to pull off a build.
What I need is their library trunk.
I know an old boy that did all out RTOS work. I will let him poke around with this and see what he says. He daughter programs for me. I am not given much hope.
HK should put out an SDK or API. As least for the IO.
Version 1.22.0.1
Variant 'PREM_NA'
Name Version Path
LAB has 3 videos, one on the boom box system, one on ride planner and one on how to up grade maps, dealers and system files. They cost $20 each and are excellent. I have all three and refer to them often.
Lots of good you tube videos online. Watch a couple, then connect your battery tender, press and hold the button down on the top left switch pack and play with the system. Just go to every module and option until you have seen them all and you will then understand what it can do and how to get there when you need to.
I think the hardest part of learning the Infotainment is which buttons have a 'press-and-hold' feature and what they do - once you learn all of those, you can do just about everything you need to do without physically touching the head unit. YouTube and RTFM really helped me learn mine...
schumacher
06-25-2009 08:16 PM
