clutch will not work
Old Nov 17, 2022 | 05:10 PM
Woodyjames's Avatar
Woodyjames
Stage III
Default clutch will not work
i have a 91 haeley xlh1200 sporster sc reaming eagle and the clutch does not work I had to replace the bearing around the adjustment screw put everything back together and set it like its suposy to .i turned my adjustment svrew intill I seen the lever move out on its owenand then took up slack at the cable.pulled the clutch in seemed like it had tension and then the lev efr hit the handlebar and nothing again no cluych
Old Nov 17, 2022 | 05:46 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Congratulations on your first post to HDF, to the Forum.
1. Hopefully, you have a factory service manual for your bike, if not get one as you will be ahead of the game for any repairs.
2. Go here to see how to adjust correctly and what you may have missed when adjusting: http://sportsterpedia.com/doku.php/t...vo:priclutch01
3. Sounds like you did not follow the procedure in the service manual, revisit the clutch adjustment.
4. The bearings in your ramp may not be seated correctly.
5. Sometimes it takes a few tries to get the adjustment correct if you have not done it before.
Old Nov 17, 2022 | 10:01 PM
Damnbiker's Avatar
Damnbiker
Could also be as simple as the clutch cable broke. Always start with the simplest things first.
Old Nov 19, 2022 | 06:56 AM
Woodyjames's Avatar
Woodyjames
Stage III
Default 91 xl1200 sporster screaming eagle clutch bearing problems
hello out there again my forum brothers and sisters,I recently was scooting down shermanway on my bike and went to pull the clutch in and the lever hit my bar.got the bike home and took off the primary cover and discovered mt clutch bearing was ate all to **** nothing left but the housing ordered the replacement bearing for the ajusterskrew and put the bearing around the ajuster skrew and put it back in the clutch plate put it back in the housing and put the snap ring back in snap ring popped off after I pulled the clutch in and had to do it over like three times once I didi it I guess I put the bearing to far back and it was hard o turn and the the snap ring popped off again so here I am opening the primary case again is there any curtain way that clutch bearing s suppose to go into the clutch plate because I put it all back together and that snap ring pops off again and no the snap ring is not bent please any body please break down this procedure to me because I'm stuck with out my bike.thank you for your time brothers and sisters I know its valuable
Old Nov 19, 2022 | 08:16 AM
bustert's Avatar
bustert
the xlforum is the place to be, sportster specific.
i assume you are talking about the throw out bearing. which bearing, radial as in original or angular contact as a better replacement? these must be install correctly as the are one way. however, it should not affect the spacing for the retainer ring. i would examine the groove, it must be sharply square, if rounded a tiny bit, probably will pop out when loaded.
Old Jun 5, 2023 | 07:12 PM
Woodyjames's Avatar
Woodyjames
Stage III
Default shifting clutch problems 91xl 1200 screaming eagle
I have a 91 screaming eagle xl 1200 not going into the proper gears and my clutch is slipping really bad replaced the clutch plates got a new clutch cable don't understand what's going on
high reverse bike goes no where
Old Jun 5, 2023 | 09:29 PM
Screamin beagle's Avatar
Screamin beagle
I see the best weed still comes outta California.
doxbike
Pan America
Nov 2, 2023 05:26 PM
fabrik8r
Aug 30, 2022 08:45 PM
davebeck
Jul 2, 2021 09:22 AM
TalkLikeAPirate
May 28, 2007 05:17 PM
WARG
Jul 29, 2006 10:46 PM
