CVO question
Old Oct 21, 2011 | 10:19 AM
Tony P's Avatar
Tony P
Default CVO question
Does the new CVOs run hot like their standard counterparts?
Old Oct 21, 2011 | 10:33 AM
Texas Fat Boy's Avatar
Texas Fat Boy
I'd say hotter
Old Oct 21, 2011 | 10:51 AM
LA VIC's Avatar
LA VIC
I agree with hotter. I had a Limited and it was pretty warm. My CVO is definitely warmer. I gutted the CAT out of the head pipe and added the night rider FL-VIED-10 AFR's set at 14.1. Helped a lot and didn't hurt the mileage. Get about 43 mpg running in the low 70's on the highway. My 103 Limited with the PCV while cooler, would never break 39 mpg. Taking off the lowers will make a difference but I don't care to do that.
Old Oct 23, 2011 | 11:07 PM
Tony P's Avatar
Tony P
Thanks for the responses.
Old Oct 24, 2011 | 06:52 PM
dlrshort's Avatar
dlrshort
Hotter and very leanly tuned from the factory.
Old Oct 24, 2011 | 08:23 PM
SteveO's Avatar
SteveO
Hot to the point of being unbearable, burning your leg hot, very lean and rough running and melting the rear brake switch leaking fluid and loosing rear brakes.
HD Has a major recall going.
Quality American Product..............wait that's not true, most of the parts are foreign ............at least made/assembled in America, or is it really ??
Old Oct 26, 2011 | 01:45 PM
Tony P's Avatar
Tony P
Originally Posted by SteveO
Hot to the point of being unbearable, burning your let hot, very lean and rough running and melting the rear brake switch leaking fluid and loosing rear brakes.
Quality American Product..............wait that's not true, most of the parts are foreign ............at least made in America, or is it really ??
Man, that sounds serious...
Old Oct 27, 2011 | 10:17 PM
SteveO's Avatar
SteveO
You will need a pair of Kevlar insulated, water cooled pants its so hot !!
And need an eye glass strap to keep your glasses on it vibrates so bad !!
Remember to keep your mouth open when idling to keep from chipping teeth !!
Wait another week I'm sure you will have a recall.
SteveO's Avatar
SteveO
Old Oct 28, 2011 | 03:43 AM
plasmadaddy's Avatar
plasmadaddy
Changed out my pipes, heat not really a problem now except in a traffic jam!
