LMAO about this seal!
yea Harley was having issues with primary and engine oil blending so they turned the seal around mid 90s I believe
2 things - 1 its a double lip seal BUT you always see oil leaking out of them like a timing chain seal on a car out the front so yea that might be a good idea
2 but the issue was not the seal its was the sprocket shaft forged in the block race that was coming loose on many blocks that the oil issue was about
you can re install it that way and NO they were never sir clipped in like a knuckle and early pan
Nick Sorgio (05-15-2017)
on a good motor never seen a difference what way its installed - the correct tool we use has no issues with the install, but it is easier flat side out with out, but use a big washer and a spacer so it goes straight - the thread can be used as well and a spacer / washer to pull it in just flat no need to push it in more, at one point the seals race will bottom before the seal is home just go easy then tap it in place
Bill wallace (05-16-2017)
