Timing plug thread size
Old Jun 28, 2018 | 10:35 PM
1Fordman's Avatar
1Fordman
Default Timing plug thread size
What's the thread size for the timing plug? The stock cad plated one threads in and out smoothly and case threads look good. Got a new Colony chrome plug and it starts then gets hard to turn, threads look good. Don't want to garf any threads, so would like to clean the case threads and run a die on the new Colony plug.
Old Jun 28, 2018 | 10:40 PM
TwiZted Biker's Avatar
TwiZted Biker
Gotts watch the chrome build up on those fancy plugs, sometimes it's too thick and will gall the threads. I lost one that way, had to oversize the hole.
Can't remember the size off hand sorry.
Old Jun 29, 2018 | 05:55 AM
johnjzjz's Avatar
johnjzjz
i think its 5/8 X 18 thread but will pull my tap out to check if I remember today
Old Jun 29, 2018 | 06:07 PM
johnjzjz's Avatar
johnjzjz
yep 5/8 X 18 is the thread
we cut a new tap off deep so we can clean the short block thread with grease on it ( two car garage green grease ) for tiny chips
Old Jun 29, 2018 | 10:03 PM
1Fordman's Avatar
1Fordman
Thank you, went out to the tool box thinking "I have that size". No such luck, have 5/8 X 11. So off to the hardware emporium tomorrow.
Old Jun 30, 2018 | 05:36 AM
FreedomRider's Avatar
FreedomRider
as mentioned, I would bet your problem is with the chrome on the new plug … you will need to run a die over it to cut the excess chrome build up
Old Jun 30, 2018 | 03:02 PM
johnjzjz's Avatar
johnjzjz
in a pinch you can use a thread file # 18
nukeone01
Engine Mechanical Topics
Jun 12, 2015 06:53 AM
PPBART
Mar 6, 2010 08:58 PM
dg7080
Exhaust System Topics
Mar 8, 2008 11:09 AM
cruncher
Ironhead
Oct 10, 2007 02:16 PM
m.breen
Jun 17, 2007 11:24 AM
