Brakes
Old Jul 14, 2018 | 07:37 AM
edalfa's Avatar
edalfa
Default Brakes
My 76 FLH has GMA brakes with stock master cylinders. I'm at the point where I have to decide what to do. Do I chase down a complete banana caliper set up or do I replace the master cylinders with the specified 5/8 bore cylinders? What do you think works best? GMA has a replacement front cylinder with or without provisions for switches. I like the cleaner look of the pre disc bikes so I'm thinking of going that direction. It looks like the pre-disc setup had the starter on the right and the horn on the left with a toggle for high beam on the headlight housing. What about turn signals? Finally, what impact on value would this have?
Old Jul 14, 2018 | 07:53 AM
Uncle Larry's Avatar
Uncle Larry
Do I chase down a complete banana caliper ... You'd be better off resoling your boots and doing a "Fred Flintstone"
Old Jul 14, 2018 | 08:16 AM
johnjzjz's Avatar
johnjzjz
if the bike was worth 350,000 dollars you have a point - retro the bars is a thing that has an appeal to many - the directional control has a corresponding switch just like the hi beam switch except its three position and not 2
they sell a complete handle bar set up for internal throttle and wires that is also in play for those who want to go that way
using a GMA master will fix the brakes and the bike will stop as it should < with a GMA system and that's 100 percent over the banana, BUT you will need to drill the bars for wire holes and screws for the switches, and the holes are in a different spot then switch cover holes, just so you know the bars you need for this have NO indents - plain round 1 inch
Old Jul 14, 2018 | 08:45 AM
edalfa's Avatar
edalfa
It's not worth $350,000.00? Damn! I come from an antique car background so I guess I think in terms of maintaining originality. Thanks for the heads up on the handlebars. It currently has an S&S so internal throttle is not a consideration.
Old Jul 14, 2018 | 12:11 PM
johnjzjz's Avatar
johnjzjz
This has had an S&S and it has internal throttle just so you know
Old Jul 16, 2018 | 09:06 AM
edalfa's Avatar
edalfa
Nice Johnjzjz! Is that frame cover below the seat a factory part? I like the looks of it.
Tukt0yuktok
Shovelhead
13
Feb 19, 2025 08:11 PM
Mumblemouth
Oct 15, 2017 10:13 AM
jeffbetrollin
Aug 14, 2015 11:28 PM
outfishin35
Jun 5, 2009 07:48 AM
pococj
EVO
Feb 28, 2009 07:27 PM
