mating 2 different engine cases
Old 10-10-2018, 03:58 PM
coax9952's Avatar
coax9952
coax9952 is offline
What's common wisdom on how many times you can shave those cases before you start running out of Meat?
Old 10-10-2018, 04:04 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,590 Likes on 2,901 Posts
the paper gasket is .020 james gaskets and its forgiving - the deck height of the piston is more important - even more when running big cams as you loose the angle - piston valve cut out to valve fitting the pistons machined area - the more you reduce the distance the valve moves to the top of the piston and hits at the very top not angled correctly - again you need experience screwing around with all the unintended consequences
Old 11-21-2019, 11:43 AM
Chris Chmielnicki's Avatar
Chris Chmielnicki
Chris Chmielnicki is offline
Stage I
Default I sh
I shattered the right side case on a 1991 80 evo. I got a used right side case from an 86. I mated them and looks like a perfect match. Rotating assembly is nice and smooth. Should I get it line honed?
Old 11-21-2019, 12:15 PM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,057 Likes on 1,511 Posts
Absolutely Must... and while yer at it... at least take a skin cut on the deck and mounts...I'm a COB and I do it that way!!!
BobRR
07-13-2019 09:07 AM
dejay96
Shovelhead
09-04-2017 04:18 PM
Lawdawg
03-27-2015 02:12 PM
davepapa
07-14-2012 02:48 PM
TA Motorsports
03-29-2011 09:52 AM
Quick Reply: mating 2 different engine cases
