engine numbers
Old Sep 4, 2017 | 04:44 AM
dejay96's Avatar
dejay96
Default engine numbers
1984 fxe shovel engine has the engine NO: stamped on the primary side under front cylinder is this posibble?
Old Sep 4, 2017 | 06:09 AM
johnjzjz's Avatar
johnjzjz
you could pull the cam cover off and inside the right side cases in that era, they were stamping the engine number on the vertical wall towards the front, some even had belly numbers if they were a factory replacement under warrantee
Old Sep 4, 2017 | 10:11 AM
panz4ever's Avatar
panz4ever
My 84 FLH has the abbreviated VIN number stamped on the left side of the case just below the rear cylinder. Came from the factory that way.
Old Sep 4, 2017 | 04:18 PM
hellonewman's Avatar
hellonewman
Mine is right there on the front of the engine case, right side near the base of the front jug. Abbreviated VIN as well.
TA Motorsports
Mar 25, 2026 03:42 PM
tenacean
Jan 7, 2024 07:54 PM
darren92530
Shovelhead
13
Nov 21, 2019 12:15 PM
BobRR
Jul 13, 2019 09:07 AM
stephtell
EVO
Oct 8, 2016 05:23 AM
