the frames center post
Old Apr 21, 2020 | 03:13 PM
glenny49's Avatar
glenny49
Default the frames center post
Hello everyone again.Can anyone tell me if the center post dimensions,both inside and outside,are the same for the fxe and the flh?In other words could you install fixtures some would call them and i would probably call them collars in a fxe that are used in a flh for a pogo sprung seat.
Old Apr 21, 2020 | 04:27 PM
Baird's Avatar
Baird
Probably, what year FX ?
They're bushings part # 47094-58
Old Apr 21, 2020 | 07:11 PM
johnjzjz's Avatar
johnjzjz
agree not only can be done but its almost standard if you want an old look
you do have to fab a bottom plate to retain the pogo or it will fall right to the ground
you will have to install a bushing and the bushing installer is needed - with out the installer you need more then one bushing
some FX frames need work in the tube to make this happen just so you know its not a gas cap install
Old Apr 21, 2020 | 07:12 PM
packmen21's Avatar
packmen21
+1
Old Apr 22, 2020 | 12:59 PM
glenny49's Avatar
glenny49
Ok,thanks for your input.The year of fx is 1975.I would have thought all fx bikes center posts would have been the same.Would you mind telling me what ones are the same as the flh and which ones aren't,in terms of years that is?
Old Apr 22, 2020 | 01:04 PM
glenny49's Avatar
glenny49
Thanks for your input.Would you mind telling me what kind of work inside the tube are you referring to.
Old Apr 22, 2020 | 02:57 PM
johnjzjz's Avatar
johnjzjz
on the frame line the tube may or may not have been totally machined we are talking AMF btw
order a bushing and the tool v twin has the tool but if you have a lathe you can make one its a hammer install stepped piece of steel
you will need the back of the bike up about 2 feet or more - not only to see what your doing but drills and tools for the bottom plate - seen them bolted and seen them welded in place
the pogo has a mushroom washer with a flat side - that is machined so the bottom nut has a stay to tighten the works in place - so your plate needs that mimicked
Old Apr 23, 2020 | 09:00 AM
glenny49's Avatar
glenny49
Ok Johnjzjz,thanks for all of that good information,you sound like you know your onions.
ptl203
Northeast Tri-State Area
Aug 28, 2010 12:54 AM
scootertramp
May 19, 2008 09:23 PM
SeaHag
Dec 23, 2006 07:26 AM
