Solid pushrods vs adjustable
Old Nov 29, 2022 | 12:17 PM
1981 suprglide's Avatar
1981 suprglide
Default Solid pushrods vs adjustable
hey I think you get more power from the solids but are they rated better? that question been tossed around a long time need an answer
Old Nov 29, 2022 | 01:32 PM
smitty901's Avatar
smitty901
Simple you go solid if you pull the heads. If you don't pull the heads you go with adjustable.
No idea why you would get ore or less power with either.
Old Nov 29, 2022 | 01:54 PM
Racepres's Avatar
Racepres
On a Shovelhead????? Only choice is adjustable pushrods... With, Hydro or Solid Lifters....
I don't believe "More Power" lives in lifters nor Pushrods... Evo nor Shovelhead...
Old Nov 29, 2022 | 02:04 PM
2500hdon37s's Avatar
2500hdon37s
Solids are lighter weight than adjustable. So minimal gains from the efficiency of less reciprocal mass in the engine. Although, the difference is extremely small.
Old Nov 29, 2022 | 02:05 PM
tngarren's Avatar
tngarren
I will worry about pushrod performance when MotoGP calls me up. I suspect laying off the gravy and biscuits are a better performance mod.
Old Nov 29, 2022 | 05:40 PM
Joe12RK's Avatar
Joe12RK
How are you going to adjust your valves with solid pushrods?
Old Nov 29, 2022 | 05:50 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Post #3 gets the Chicken dinner.
Old Nov 29, 2022 | 05:51 PM
1981 suprglide
yeah right I never could get the hang of adjusting them that bleed down stuff could never get that right
Old Nov 29, 2022 | 06:23 PM
Changing Gears 4ever!'s Avatar
I dare anyone to try and dyno the difference.
Jeff
Old Nov 29, 2022 | 10:24 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Jeff
I dare anyone to find one piece pushrods for a 1981 Big Twin...
