Quick question on inserts. My rear plug weeps oil when I ride, the insert had come out with the plug once a year or so ago, at the time I slapped locktite on it and put it back in, seemed to work ok. I figure it's about time I fix it properly.
The question is...for aluminum heads should I use aluminum inserts, so they expand and contract at the same rate as the head or is there merit in using steel or carbon inserts?
i use whats called a keensert they have 4 tiny prongs you tap in when done to keep it from moving-- when i have the head off of the engine (best fix) i tig a bung in and its a done deal -- even when i do dual plug heads i tig a long reach bung in .. google the word "keensert
They make a one piece steel insert the wedges in place and I use a permanent grade loctite one them , kits can be had in decent auto supply store . I've done a bunch of them , can even do it with the heads on with a little care .
there ya go stick-- what can make the insert leak is running the tap in to far and the insert is loose -- those works and work well -- im just fond of the keenserts because of the 4 lil pegs --- http://www.google.com/imgres?q=keens...9,r:2,s:0,i:81
The insert that came out was one of the steel ones with the knurl at the top that you give a whack to fit in place. I've read conflicting accounts on whether steel or aluminum (or other) is the better type of insert to use. I'm using a flanged (timesert) type...just gotta decide aluminum vs steel
the ones in the pic never move,leak,ect -- find a good tig welder and have a bung welded in (have to remove the head and all the parts)-- sounds to me that whoever installed it tapped to much -- 3m makes a thread sealer that is NOT removable --Rite-Lok™ Threadlocker TL62-50
