Shovelhead noise?? loud hollow ping
Old 06-30-2013, 01:39 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is online now
Received 48,295 Likes on 17,615 Posts
Originally Posted by johnjzjz
i am not in an ears shot of this BUT i have had that same issue and it turned out to be the connecting rod bearing roller and or the crank pin had failed --
the 3 i have seen have been the hardness had gone away in the crankpin rear rod area all on one side, and this caused the pin to chew up and start to make odd to say the least noises
This or the rear exhaust guide is working loose in the head , had a couple drive me crazy chasing that gremlin .
Old 06-30-2013, 02:51 PM
Krutch's Avatar
Krutch
Krutch is offline
Location: somewhere in "The Peoples' Republic of Illinois
What do the rockers look like where they contact the valve stem ends? Any flats or chips in the surface can manifest as noise. They can also promote wear in the guides.
The curve of the rocker end is a variable curve not a true radius, by the way.
Old 07-04-2013, 09:29 AM
seansheatattoo's Avatar
seansheatattoo
seansheatattoo is offline
4th Gear
Rockers look good, rear exhaust guide looked good too. I am pulling the top end off again tomorrow, and trying out a different top end all together. A friend has a spare bike and is letting me try that top end to see if it fixes my problem. the cam seems to be fine, but the noise is worse with the stock cam and it definitely sounds like a valve hitting something and the sound comes right through the pipe, when you ride it with the stock cam, I could hear the valve hitting then the sound echoing through the pipe.. what a pain, but at least I think i am narrowing down the issue. I should buy stock in James Gaskets, the amount I have already gone through trying to find this problem.. lol
Old 02-21-2019, 06:50 PM
BIGJPW's Avatar
BIGJPW
BIGJPW is offline
Stage II
Hi I know its been several yrs...what was the issue?
Old 02-21-2019, 09:14 PM
hellonewman's Avatar
hellonewman
hellonewman is offline
Received 5,894 Likes on 2,514 Posts
The OP hasn't logged in since 2013 so don't hold your breath for a reply
Old 02-21-2019, 10:38 PM
1981 suprglide's Avatar
1981 suprglide
1981 suprglide is offline
look somewhere you not getting the right amount of oil check for metal shavings
drain the oil tank clean all hose entry had a friend mess around left his oil tank cap open and few tree leaves got into it
eventually blew that engine to kingdom come after hearing noises like you hear
Jason Mcadams
Shovelhead
10-10-2016 11:28 AM
Godzilla88
06-15-2014 07:58 PM
Danzyg1
07-29-2010 11:53 PM
sws1
09-24-2007 06:29 AM
mtnlvr
Exhaust System Topics
04-22-2007 12:46 PM
Quick Reply: Shovelhead noise?? loud hollow ping
