Another Zumo option for Road Kings
Old Feb 16, 2008 | 01:58 PM
rde's Avatar
rde
Default Another Zumo option for Road Kings
I finished up my Zumo mount this week, and thought I'd share my thoughts on a clean install for owners of Road Kings.
Since we don't have a power outlet on the handlebar I opted to use a Powerlet socket. If you pay close attention you'll see all the wiring is sealed from the elements. I had intially planned to use a Powerlet power cable to the socket, but in the end decided to use the more flexible power cord that comes with the Zumo. I did keep the plastic female socket attachment and soldered the Zumo cable wiring to the female Powerletsocket attachment. I received the black rubber housing for the female attachment from Powerlet.The wiring runs into the nacelle and is practically invisible.It's now totally sealed from the weather.
I had my dealership do the nacelleinstall since I wanted the powerlet socket turned on and off by the ACC switch. They charged me .5 hours of labor to do this.
I then went with a chrome Ram mount to leave permanently attached to the handlebar. I added some shrink wrap to the U bolt.
The whole idea behind this is to be able to quickly detach the Zumo but leave behind a clean chrome installation that doesn't interfere with the clean lines of the handlebar.
Here you see the Zumo cradle powered into the Powerlet socket. I bought the short Zumo power cable from Powerlet that has the appropriate plug to fit the socket. It's still all fused to the low amp fuse on the Zumo power cord. It's hidden up inside the left nacelle to change if necessary.
Here's the finished product.
I had seen alot of install ideas for other baggers, thought I'd share what I did with my Road King.
Old Feb 16, 2008 | 02:13 PM
dawg's Avatar
dawg
Default RE: Another Zumo option for Road Kings
Very nice. I have a zumo 450 on the way and have to figgr out how I want to install mine on my ultra wiring wise and where to mount it as I ain't moving my cup holder, so hopefully it'll fit.
Old Feb 16, 2008 | 03:25 PM
Badbagger's Avatar
Badbagger
Nice clean install.
Old Feb 16, 2008 | 05:39 PM
Pastor John's Avatar
Pastor John
Really nice install - love the chrome brackets!
Old Feb 16, 2008 | 05:55 PM
floridamk's Avatar
floridamk
Very nice and very descriptive! Looks great!
Old Feb 16, 2008 | 07:42 PM
btefft's Avatar
btefft
Nice job.
Hack
Old Feb 16, 2008 | 07:45 PM
djamann's Avatar
djamann
Nice looking install. Doesn't the Zumo cable from Powerlet have a fuse in the plug? I was expecting it to, that way you wouldn't have to open up your headlamp to replace the fuse. I wan't to go this route as well but just didn't have the $150 to shell out at this time
Old Feb 16, 2008 | 08:40 PM
rde's Avatar
rde
Actually the Powerlet Zumo cable does not have a fuse. That is why you need to use the Zumo power cable that comes with the Zumo 450 or 550. It has an inline 2 or 3 amp fuse which is what you want for the Zumo. Don't use a 15 amp fuse! My fuse is accessible inside the left portion of the nacelle-I don't have to take off anything. The power cord has a bit of slack and is tucked up inside with the fuse attached
If I want to use the Powerlet socket to power heated gloves I will simply change out the fuse to a 15 amp, should take 15 seconds.
Powerlet also makes a Gerbing plug attachment for heated gloves. Next winter I plan to pick up a pair of G3's now that I can use them!
Old Feb 17, 2008 | 04:08 AM
PapaTravis's Avatar
PapaTravis
Looks really clean... do you have a link to where you got that powerlet thingy from... I am not sure I have ever seen one... Am I right in assuming it is simply a 12v power source, like a cigarette lighter socket?
Old Feb 17, 2008 | 06:53 AM
edeluxe07's Avatar
edeluxe07
go to www.powerletproducts.com They have accessory cables and plugs for almost any device. The plug type is not a cigarrette plug....stays securely in place much better.... Also referred to as a BMW type plug, as bimmers have this type of plug on them. They have kits for softails, handlebar mounts (as in this thread), and even tour pac/saddlebag plug kits.
