What did you do to Your Sportster Today?
Old Jun 1, 2016 | 03:03 PM
  #3351
deadrubberboy's Avatar
deadrubberboy
After relocating my coil to under the cow bell I needed to move my horn. I got an "OEM Replacement Car horn" from Advance Auto to put in the front down tube area like the non Custom models. After making up a bracket for the down tubes I ended up finding a place to stash the stock horn. Since the OEM horn was so cheap I figured I'd try to wire both up. It works!
Now I get simultaneous high tone "Meep!" from the new horn, and low tone "Honk!" from the original. Combined they're pretty loud.
New Horn "Meep!"
old horn from under Cowbell "Honk!"
Also made a DIY tank lift our of some spacers that came with a TV Wall Mount. Since I have a 1200C with the under bar speedo, I couldn't use the commercially available options. This got me 1". Subtle, but I'm happy with it.
Tank clearance
Hopefully the new sissy bar goes on tonight!
Old Jun 2, 2016 | 12:17 PM
  #3352
deadrubberboy
Default Sissy Bar and coil under cow bell
Stoked on the sissy bar I got from Edward Richie: https://www.etsy.com/shop/EdwardRichie
He custom made it to accommodate my seat (generic seat from swap meet I had to modify to fit).
Also, here's some pics of my recent DIY coil relocation under the cow bell...
Coil under cow bell. Using stock wires. Second long wire donated to me from awesome forum member
Coil under cow bell
Old Jun 2, 2016 | 06:13 PM
  #3353
cbs_24's Avatar
cbs_24
New tires and 5k service
Old Jun 2, 2016 | 06:44 PM
  #3354
WVDevil's Avatar
WVDevil
Changed to heavier fork oil due to noises and it just not feeling right.
Bumped the bar height up another 1/2" while they were off anyway:
Old Jun 2, 2016 | 08:34 PM
  #3355
WVDevil's Avatar
WVDevil
Originally Posted by TStephen
That'll work . Use the braided line for looks because performance is not an issue.
Also, what's the reason for the filter? There's no intake on these vent lines so.......is it just for looks? How long will it take to clog it up I wonder and if it clogs will it restrict venting?
I would rout the hoses below the frame and terminate them with an open end zip tied to the frame rail. The minor amount of blowby won't create a hazzardous situation.
This plan is going sideways. The chrome hose ends I got from DK don't fit. Diameter is too big to go on the banjo fittings :/ Might be able to space it out with some washers, not sure yet. Have to be sure the banjo lines up. I'll work on it.
Old Jun 2, 2016 | 09:12 PM
  #3356
TStephen's Avatar
TStephen
The simplest things are always the most aggravation.
Old Jun 3, 2016 | 01:24 PM
  #3357
WVDevil's Avatar
WVDevil
No ****, right? Here's what I did today:
Certainly better but not throwing away the old bolts....
Old Jun 3, 2016 | 01:39 PM
  #3358
TStephen's Avatar
TStephen
Looks a damn sight better doesn't it? Wouldn't it be cool if you could hard pipe it with some chrome supply lines? They're chrome plated, soft copper so you could bend them where you want them.......But nah...
Old Jun 3, 2016 | 01:53 PM
  #3359
WVDevil's Avatar
WVDevil
Maybe someday....
Old Jun 3, 2016 | 02:35 PM
  #3360
TStephen's Avatar
TStephen
Painted my back wheel (late into the night last night) over a couple cold Yuenglings. I used the kitchen table (wife's out of town) to tape it up and sprayed it in the shower (just kidding) with satin epoxy paint.
I'll be cleaning and painting the front one tonight while I finish off the last of the 12-pack.
