Stage IV on order ... But.. ? .. However.. !
Old Jan 24, 2017 | 08:33 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Originally Posted by Ultra61
I do want to feel comfortable.. us M8 dudes are just chomping to see what this engine will do inside the warranty.. this is the struggle!
I'm saying without being way outside ignorant.. If I did the Stage IV .. I would not be able to put a torque cam in without a proper tune?? w the wideband/smart tune putting a Torque cam in the Smart tune will not adjust is how I understand it.
The only way you can keep warranty is:
Run the Torque cam as a Stage II
Run a Stage III with a 498 cam
Run a Stage IV with a 515 cam
The new Smart Tune Pro Auto Tuning Module must be run with Pro Street Tuner with any of the above kits.
Any other combination of HD SE parts breaks you warranty. Add a aftermarket anything to the driveline that is NOT EPA/ARB approved and warranty is OUT.
Old Jan 25, 2017 | 03:40 PM
grande78's Avatar
grande78
they have the kit on the Harley Davidson web sit but they do not say anything about a new tuner. i looked at the pro street tuner and it does say it will work with stage 4 . do you guys know the part # to the new unit ? thanks .. found the part #
Old Jan 25, 2017 | 05:25 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
The new Tuner module is an add-on to the pro street tuner, it does not replace it.
P/N 41000445 @ $399.95
Old Jan 25, 2017 | 05:31 PM
Ultra61's Avatar
Ultra61
Interesting they are not promoting the Smart Tune but only for the Stage IV .. Wideband O2 should help IMO as a nice add to the all set-up's they offer.. but there I am assuming again.
Thanks for your input Steve on this thread.
Old Jan 25, 2017 | 08:28 PM
SWThomas's Avatar
SWThomas
Edit: NM, I found it.
Old Feb 2, 2017 | 12:51 PM
grande78's Avatar
grande78
Ultra61 any updates ? i am about to order this kit and would like your feed back on it .
thanks,
Alex
Old Feb 2, 2017 | 01:27 PM
DRBUICK's Avatar
DRBUICK
I have my stage 4 kit on just waiting for the frame to come back. I put my stage 3 on eBay let's see what it brings. But I did custom pistions to make mine a 120 inch
Old Feb 2, 2017 | 02:39 PM
grande78's Avatar
grande78
DRBUICK did you get your kit from your local HD Dealer or did you order it online ? if i order it online i save about 300 then i can use that for the dealer install
Old Feb 2, 2017 | 03:42 PM
DRBUICK's Avatar
DRBUICK
the stage 3 I bought from the dealer. the stage 4 kit i bought all the parts separate because i bought pistons and cylinders to make mine a 120 inch
took all my stage 3 parts out and put on eBay.
If you ask the dealer for 20% off most will if your getting the labor done at the dealer that will save you 520.00 on the kit
Old Feb 2, 2017 | 03:43 PM
DRBUICK's Avatar
DRBUICK
