* HOW TO * under fifty bux *
Old May 9, 2009 | 12:26 AM
  #1241
Jude1986's Avatar
Jude1986
Lightbulb lighter/ charger
I run my car navigation on my bike and needed a way to charge it so I installed a cigerette lighter. I didnt see it on here already, but it probably is.
I bought red and black wire, shrink wire connectors, some U shaped wire ends (whatever they are called), a fuse holder and fuses, and the lighter. All for about 25 at an auto parts store. I connected the U shape ends to the wire and to the battery. Ran the wires up under the seat, put the fuse on the red. Connected both sides with the shrink connectors. Next I drank a beer, then pulled that chrome strip with the gauges and ran both wires under. I taped them together on the other side of the panel with electrical tape and connected them to the lighter/charger. I ziptied that under that annoying rattling flap on the dynas that covers the risers. Thats it.
I have used it with my nav and charged up the phone a few times when camping.
Old May 14, 2009 | 04:10 PM
  #1242
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Default polish spokes without hurting your fingers
In order to avoid sore fingers after cleaning the spokes, I made a few tools. Have fun making and using them!
1) Take a metal type coat-hanger and straighten the wire
2) Fold the two end towards each other and close the eye tight using pliers or a hammer
3)Bend the eye about 45° and solder both wires together to strengthen the tool
4) Cover the handle part using duct tape
5) Fold a piece of steel-wool together, slide it in the eye and apply a few drips of aluminum polish
6) Now you will be able to get access to every part of your spokes
7) Use a piece of cloth to finish the polish
8) You can also use an old tooth brush which is extended by using a piece of PVC pipe (as used to cover electrical wires)
Last edited by FXD2003Rider; Jan 28, 2020 at 01:24 PM. Reason: re-posted blurred images
Old May 14, 2009 | 04:16 PM
  #1243
mud's Avatar
mud
Good one 03Rider. Simple and effective.
Great for the European winters as well.
mud
Old May 14, 2009 | 06:20 PM
  #1244
JRK5892's Avatar
JRK5892
agreed! what a simple yet very effective trick!!!! nice work!!
Old May 21, 2009 | 05:43 PM
  #1245
Turn2HD's Avatar
Turn2HD
Not much of a mod but I wanted something I could use to tap the 12V when I needed it and also use as a socket for a battery tender. I've seen it done on this thread just not in the same location I wanted it inconspicuous but handy so I could reach from a riding position or sitting on the ground by the bike. I mounted it to the bottom of the electrical cover and ran the wires through the electrical box under the seat to the battery and fused it next to the battery. Water proof socket 8$
Old May 25, 2009 | 07:03 PM
  #1246
maddghost's Avatar
maddghost
perfect for cell phone charger!
Old May 27, 2009 | 12:16 AM
  #1247
slomotion's Avatar
slomotion
Default horn cover cowbell
Bored with the cowbell I painted a stripe down the centre and arrowhead 2/3 of the way up. I did this about 6 months ago without sanding. Im sure it would easily scrape off,if I wanted to remove it. Cost 0$. I call it " Portrait
of a Lady" If you dont see it, look again. It looks like every woman Ive known.
You may recognize someone you know in it.
Old May 27, 2009 | 12:57 AM
  #1248
slomotion's Avatar
slomotion
Default AC cover
Variations on this have been done here but here's my take on it.
went to the flea market and bought an aluminium pot and a chrome candy dish. With a dremel I cut them to the approx. diameter of my filter. The pot bottom was painted with a skull and drilled in the center.
The candy dish had 3 legs. I snapped them off and drilled holes for 3 small bolts to hide the marks. Then drilled a centre hole and used a spacer behind for mounting. Cost- dish plus pot $1.00
Old May 27, 2009 | 08:07 PM
  #1249
maddghost's Avatar
maddghost
Slomotion , I had to look again and just when I was ready to say "he's lost it" Boom there she was staring right at me! Brilliant! I have to have one of my own! thank you for sharing!
Old May 27, 2009 | 08:16 PM
  #1250
SC-Longhair's Avatar
SC-Longhair
That's awesome. Very cool.
