Heated Grips Always On...
Old 09-21-2018, 04:49 PM
aufirefighter1's Avatar
aufirefighter1
aufirefighter1 is offline
Stage IV
Default Heated Grips Always On...
This is a bit different from the other few heated grip threads....
My grip heaters just decided to run full blast a few days ago and they haven't cut off yet. I didn't do anything to my handlebars....all stock. The grips are stock on a 2013 Ultra Limited. The **** is turned off.....and has been all summer. Almost too hot to ride with summer gloves. I assume that the control **** has shorted internally. Any opinions? Does this mean replacing the left grip or something more intrusive? Can I wire into the unused accessory switch on the dash and use it? I am about to figure out what fuse runs them and pull it.
I have been getting some charging problems on the bike that I'm trying to narrow down to either the generator or the voltage regulator.....but they have been sporadic, and started well before this heater problem.
Thanks for any assistance,
aufirefighter1 in Dothan, AL
Old 09-21-2018, 05:14 PM
woodthumb2's Avatar
woodthumb2
woodthumb2 is online now
yep.. probably the reastat which as u know is in the left grip..but..............i have the same bike and had problems with mine heating on and off for several months... then, the charging began to go nuts whenever i used them... voltage would drop to 10 then back to 14 when grips were turned off... when my engine and batt lights came on a few times with them on i decided to replace them with the same harley grips...dealer did for one hour labor.... but problem did not clear until i changed out the VR... harley oem.. all good now... maybe i should have done the VR first ?? stranger things............
Old 09-21-2018, 07:06 PM
aufirefighter1
Stage IV
I guess you can't use the word k n o b on this forum.....maybe the dial that adjusts the reostat is more appropriate. I'm thinking that I will go back with a CE generator and rectifying regulator and just replace both of them.
Old 09-22-2018, 04:42 AM
grbrown's Avatar
grbrown
grbrown is offline
As with all electrical problems, you need to do some diagnosis first. Could be a ground, due to a damaged wire by-passing the switch, which can be easy to fix, so check the wiring and twist-grip side for any obvious signs of damage.
Old 09-24-2018, 01:18 AM
aufirefighter1
Stage IV
There's no damage to the handle. I'll check continuity on the wires later.....which probably means when my hands start getting cold in a couple months. I've still got to get to the diag on my charging system, but with the up and down I'm seeing on the volt meter, I'm pretty sure I'm going to be replacing both the generator and VR.
au
Old 11-10-2018, 05:13 PM
aufirefighter1
Stage IV
Default Diagnostic complete
Finally had time to diagnose my charging issue. VR is quite bad. 11 volts on each pin of the stator plug (on VR). I'll be ordering one of those shortly. Generator has good voltage. Battery good. Held charge for last 3 weeks since I stopped riding it due to almost losing lights one night.
No luck on heated grips yet. Continuity is good on right grip. Trying to figure out how to check the rheostat on left grip.
Old 11-10-2018, 05:29 PM
woodthumb2's Avatar
woodthumb2
i am gonna reach a little here and guess replacing your VR will solve your heated grip deal... based on my past experience with this same problem i am now thinkin i should have changed out my VR BEFORE i changed my grips.... suggest doing that and see what happens... good luck....
Old 11-10-2018, 07:21 PM
PDB17UltraRG's Avatar
PDB17UltraRG
PDB17UltraRG is offline
That were i would be right now changing the VR prior to changing my grips.
Old 11-11-2018, 09:24 AM
Vernal's Avatar
Vernal
Vernal is offline
Received 7,308 Likes on 1,907 Posts
Trying to think of a way a bad VR could turn your grips on and am drawing a blank, but i've seen stranger things. I'm thinking the switch shorted closed.
If the VR doesn't cure the Heated grips disconnect connector 189 and check continuity between the wires going to the left grip. I don't have a 2013 Elect. manual but 2010 says the grips on high draw about 3 amps. Measuring ohms on the wires going to left grips you should see 12/3=4ohm on max open on off.
woodthumb2
05-01-2018 03:06 PM
cdestuck
03-02-2017 10:31 AM
trackerman
Electrical/Lighting/Alarm
02-01-2017 11:27 AM
RWTDCT
01-17-2017 08:18 AM
Pappa P
11-18-2014 10:15 PM
Quick Reply: Heated Grips Always On...
