EFI Sportster 48 Wont Idle, Fuel from intake
Ok I'm seeking help for a problem I've been having with my 2016 Sportster 48. I'll start with how it started.
I was out riding one day at night and about 3-4 miles away from my house I could smell fuel but I had thought it was from another vehicle that had passed me. So I made my way back home and along the way the bike felt a little rough when I would accelerate at lower rpms (out of the norm). I got home and let the bike idle while I did a walk around and tried to find anything wrong but I didn't notice anything out of the norm.
The next day I tried to start the bike and it started but would die after a second or two. It's basically been doin this for a while and I've been trying to diagnose the problem and nothing has helped so far. I had gotten codes P2300 & P2303 and I set out to do the following
Things I've Tried:
Things I'm going to do:
Video of what the bike is doing
If someone has had a similar problem or knows what's going on feel free to share, I'm all ears.
Things I've Tried:
- Check Fuses
- Clean intake
- Replace Spark plugs
- Swap Plug Wires
- New Ignition Coil
- Swap Throttle Position Sensor
- Cleaned O2 sensors
- Took Fuel pump out of tank to inspect (looked fine)
- Check out injectors
- Run A Compression Check
- Swap IAC
- Swap Rectifier
If you look up the codes you will find they are coil circuit related. You're doing a whole lot of unnecessary work. Systematically diagnose and you will save time and money. Check the connector and wires thoroughly - especially if you recently had the connector off or were working in that area. replacing the coil doesn't fix a wire problem which will also set the code. Check for breaks inside the insulation too.
An open in one of those wires could set that code. You installed a coil thinking codes always mean parts - codes mean circuits which include wires, switches, parts.
An open in one of those wires could set that code. You installed a coil thinking codes always mean parts - codes mean circuits which include wires, sensors, switches, items being monitored.
Your codes don't indicate problems in the laundry list of things you are throwing at it.
Good evening guys I am have similar problems with my 06 Street Glide. My problem started after I filled up my gas tank once it was just above 1/4 tank. I rode for about 10 miles then parked my bike in the garage for about 3 hours. Then I started the bike up and then it began to run rough and back firing. Then it would start but it had no power and wouldn't stay running, I thought I must have put some bad gas in it , so I drained it out and put fresh gas in it. But it still wouldn't stay running, however it starts a run good for about 30 second and cuts off. So I did a diagnostic check and got some codes which has since disappeared. I had several codes, P0122, P0373, P0374, P1356 and P1353. So what I did was replaced the CKP sensor. I also check all the fuses and the battery is fully charged. I also changed the fuel filter and it still won't run but it still starts. So can any one tell me what I may have missed checking. I am asking before I take it to the shop. By the way I am find any codes when I do the diagnostic check.
You would be better off starting a new thread of your own with a title indicating the correct model rather than asking about your Street Glide in a thread titled as "EFI Sportster 48 Wont Idle, Fuel from intake".
Many Street Glide/Touring people may ignore the Sportster thread.
I would check the TPS (Throttle Position Sensor) connector for poor connections at the wires, damaged connections, backed out pins or possibly an unlocked connection at the connector.
I would also check the TMAP sensor connector. (I know they share the same 5 volt reference line on Sportsters)
