Warped Rotor?
Old 06-13-2019, 08:45 AM
Haarley's Avatar
Haarley
Haarley is offline
Default Warped Rotor?
When I'm rolling under 30, I can feel a bump, bump, bump, from the front wheel with every rotation. The bump goes away immediately when I apply any pressure to the front brake lever.
Old 06-13-2019, 08:52 AM
tajar66's Avatar
tajar66
tajar66 is offline
A warped rotor would be worse when you hit the brakes. Check you tire and wheel for an imperfection like a bulge.
Old 06-13-2019, 09:05 AM
tmultra's Avatar
tmultra
tmultra is offline
I had a warped rotor. My front breaks would not have pressure at first due to pads being pushed apart.
Old 06-13-2019, 11:01 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Bubba Zanetti is offline
Received 13,306 Likes on 5,674 Posts
Warped rotor will give a pulsating feeling when you grab the brakes. Your issue sounds like a tire or wheel problem.
Old 06-13-2019, 11:08 AM
Trench's Avatar
Trench
Trench is offline
Could be a bad tire, bad wheel, bad wheel bearing, bad rotor, bad caliper, bad pads, bad fork internals, stuck pad, sticky puck, neck bearings.....hope this helps.
e6fmf (06-16-2019)
Hey Man's Avatar
Hey Man
Hey Man is offline
Received 7,019 Likes on 2,822 Posts
What they all said.
Old 06-13-2019, 11:32 AM
Tommy C's Avatar
Tommy C
Tommy C is offline
Received 19,912 Likes on 6,744 Posts
If you want to know for sure check the rotor with a dial indicator.
Old 06-16-2019, 05:29 PM
Haarley's Avatar
Haarley
Haarley is offline
It is a very warped right front rotor. The rotor hits the caliper, making the bang. When the brakes are engaged, the rotor is centered, pulling it away from the caliper.
EBC floaters and Lyndall pads on the way.
blueduramax
10-10-2021 06:31 PM
Mad Max 454
09-07-2018 11:59 AM
Rain
08-12-2014 08:01 PM
clarkchriston
05-15-2013 10:13 AM
goutieboy
04-03-2012 05:53 PM
Quick Reply: Warped Rotor?
