Twin-Cooled to Centre-Cooled?
I haven’t seen a Gen2 bike in person side by side to try and compare, and the closest dealer is 300mi away. But if all these questions can be answered yes with little difficulty, the cost in parts really isn’t that bad and could be a beneficial mod for all twin-cooled models that hate having permanent lowers.
In theory the ecm signal to the twin cooled fans and pump could power the center cooled parts. There could be ohm and load difference that throw codes or cause the ECM to disable the system.
Start by going to the HD web site parts, oem parts, model and year to see how many part numbers are different and their price.
Let us know how this works out.
- heads
- valves for new heads
- ignition coil
- plug wires
- horn
- coolant lines
- Coolant reservoir
- coolant pump
- radiator
- radiator brackets
- voltage regulator
- radiator cover/chin spoiler
- transmission top cover
- wire harnesses for new voltage regulator, coolant pump, etc.
- Engine guard
- floorboard supports
You’d probably be out more than you would with a trade in for the new bike. Newer bikes are less expensive than the older style.
- heads
- ignition coil
- plug wires
- horn
- coolant lines
- Coolant reservoir
- coolant pump
- radiator
- radiator brackets
- voltage regulator
- Engine guard
1) more options for lowers. Without having twin cooled in the lowers, I could get color matched ones from Advanblack or Hogwerks. There are also many other options.
2) Lower speakers. While you can get them for twin cooled bikes, the options are far greater for non twin cooled lowers.
3) Removing the lowers.
Has anyone else done the conversion? If so, was there any issues with the ECM? It was mentioned that the flow direction is different between the two. Any issue there?
Love to hear if anyone did it, and how it turned out.
Sticking only to the cooling systems, you need to compare your bike to a '24-'25 Street Glide (Ultra or not is irrelevant). If you do that, you will see there dozens of different parts you'd need to get to "upgrade" your bike to a center-cooled configuration.
It took me 15 minutes to build this image ('24 on the left and '18 on the right). The new radiator assembly has 25 parts that add up to roughly $1,700. Luckily though, the temperature sensor is the same thus saving you $32. I don't even want to think about the harnesses. How about the ECU? Will the new cooling system provide same coolant temperature range? It'll be looking for the 2nd fan (continuity, current) and will likely start throwing codes if they aren't correct. Then there are questions about the harnesses. More questions about cooling flow and capacity. On and on...
CAN IT BE DONE? Yes, absolutely given the money and ability to troubleshoot issues and find workarounds and it would make for a great engineering project.
IS IT WORTH DOING just for more lower fairing options?
