Seems like my starter is hooked up to my flasher...?
I went for a short ride and went to set the alarm with the pushbutton fob. Lights didn't flash, but the red light in the dash began flashing. I figured I just missed seeing the turn signals flash.
When I came back out and tried to turn off the alarm, no flash, no indication. The bike tried to start. But, it acted like the battery was going dead. Try to turn over, then stop. Try to turn over, then stop.
I pulled the seat to check the battery cables. Tried to start it again and it fired right up. So, I bee-lined for home.
The right turn signal didn't work, but the left did for most of the trip. I got it home and started fussin' with the battery cables. Cleaned everything good and it fired right up-- repeatedly. I felt I had it licked!
Then, on the shakedown run, the light came on again. Got it home, and double-checked all the grounds and battery terminals again. It's been a no-start ever since.
When I have the ignition on and hit a turn signal, the backlight in the speedo display blinks to the tune of the flasher, but the lights don't.
I figured I'd sleep on it and see what tomorrow brings. I have to cozy up to the service manual to check a few things. I've heard of the TSSMs going bad, but don't want to default there. I also know that grounds can do funny things, and my bike has got enough history that anything is possible, so I'll be tracing grounds for turn signals and such. it did throw two codes, b1121 and b1122 (turn signals will not flash). The fact that the dash light, and the starter seem to "flash" leads me to think that the TSSM is still doing the "On-Off-On-Off' thing it is supposed to. Likely have a ground issue somewhere.
Thoughts?
when I got back home and shut it off, I didnt set the alarm. Just turned off the ignition. Tried starting again and no go.
hoping to get some time on it tomorrow night. Will be riding in the truck for now! 🫤
Even so, still no love. I'd love to say that my years of experience, sprinkled with wisdom led me directly to the fix, but it didn't.
It DID get me in the neighborhood though, so at least my spidy-senses are working.
I started checking the rear taillights. The first indication was that the right-side turn signal wasn't working, then both. I hadn't monkeyed with the front turn signals since I've owned the bike, but the rears have been off and on for various reasons. So, i started there.
I'd check a connection, and then try to start the bike. Nothing on the light bar made a difference. Then, since the seat was still off, I could get to the rear fender connector pretty easily. I worked the connector a few times and checked the wiring. All looked good. And, when I tried to start the bike, it DID!
I tried to look for any issues in the wiring under the fender, but my fender has the tube that the wires run through. Can't see anything. But, there are no connections between the fender connector and the taillight, so if there isn't any evident damage, I'm assuming the wire(s) aren't damaged.
I've started it numerous times, and it always fires right up. I rode it to work today and used the alarm (fob) and everything worked as intended. I'm callin' it a win!
I DO feel a bit of relief that it doesn't appear to be a TSSM on the outs. That was my main concern. Not saying it won't, but they usually don't "fix themselves".
Will update this thread if the gremlin returns.
Was just hiding.
I took the bike out for a ride and stopped at the local H-D dealer. On the way there, he popped his head up again and the turn signals started going goofy (not working) and it threw the code(s) again. It was on-and-off acting up. I get to the dealer and I set the alarm as usual, watching that the lights and all would flash accordingly. Everything looked fine. When I went to leave the dealer, the bike wouldn't respond to the fob. The light was still flashing in the dash, and it wouldn't start. And, the turn signals wouldn't flash like the alarm was going off. I don't have the siren.
I pulled the seat and monkeyed with the usual suspects. I pulled the dash, since the backlight would flicker when this happens. Nothing worked. I had a couple of guys stop by and offer help. But, of course we were trying to figure out what was going on, so no solutions were readily made.
One guy stopped by (Dan, who owns a VERY nice '04 Road King, btw) and we get talking about connections and stuff, that sometimes working them clears up the "gunk" that may be the issue. I worked through a few and then went to the fuse panel under the seat. I tried starting the bike after every attempt, and after I slightly "shuffled" each of the fuses, the alarm disengaged, the fuel pump kicked in, and the bike started. Ran fine the whole way home. So, when I got home, I pulled everything and cleaned all the terminals in the fuse block with contact cleaner and replaced each fuse in the panel. I didn't replace the relays. Didn't have extras, and didn't think to pick any up while I was out.
So, I think I know the neighborhood in which that gremlin has been living. And maybe, I might have even evicted him. Time will tell.
As an update, though, the fuse block cleaning has been working so far. The issue hasn't returned, and I've been riding it a fair amount. Got another bug to deal with, unrelated to electrical, but at least this one appears to have sunset.
The blessings of old bikes with "character,' right? LoL...
