Dating A Ratchet Top
I dont know what 2E indicates and my best guess is that it may be an inspector marking. Some other cases have E2, E1, 1E, 1, 2 or E.
The ID on the front of the case is intriguing, partly because the 9, even though it is a round-back type, doesnt look exactly the same as other examples in my photo collection. And the 3s have a flat top when l would have expected a round top. Also notice the 3s dont line up exactly with the other characters and that is interesting because most (not all) of my examples of this form of ID look like they may have been done with one strike, suggesting that all characters were contained in the one stamp-holder.
I cant see any sign that the area has been altered but what does that area look like to you? Is there any sign of alteration? If not then maybe the case is a replacement and someone used the ID from a damaged case? Or maybe the ID was applied at the factory but wasnt done with the usual types of stamps?
Apart from being called an anti-theft number, its also known as an additional original component identifying number or a security code. When stamped at the factory, the letter E was used on Big Twin trans cases for some 196669 models but other letters were also used for 196667 and 1969. And maybe for 1968?
Inside the lid and partly hidden by the fluid may be casting number 34809-52 which I imagine first appeared for 1952 models. Following that may be a circle E which may indicate Eck Industries. After the circle E it looks like EQ2 and I've seen that marking before but I dont know what those three characters represent. Next may be a lone 4 while some other lids have a lone 1, 2 or 3 in one position or another.
Provision for a switch on the lid first appeared as of 1959 models and your switch may be the type introduced then but obviously I dont know if that switch is original to that lid.
Another clue may be in the screw holes because as of 1965 model lids the screws changed to socket-heads and the countersinking appears different. Also changing to socket-heads as of 1965 models were the screws in the shifter shaft lever and shifter cover.
Some lids of that type have date codes such as 12-74, 1-75, 8/75 and 8/14/78 but I dont see a date code on your lid. But the lack of a date code doesnt necessarily mean anything because Ive seen other lids of that style without them.
I dont know what N 18 indicates. Other lids of that type have similar markings such as D3, N3, N6, N9, N12, N28 or N30.
I havent studied shifter cams much but yours may be one of the types used for 73/74 or later?
Eric
Eric
Clean it up pull the bottom studs, heat it up some doesn't take much 150-180f or so to see if there are any cracks or fracturing going on you didn't see, micro cracks pop out very visually on aluminum casting doing this. Soak it in acetone, maybe heat it once more to double check, any inclusion pockets or micro cracks will show now. All good, sealing loctite the studs in place and coat the inside with Gylptal. Those old castings were porous to a fault, they'll sweat oil.
Eric
