New 12” Handle bars, Same riser torque?
Old Apr 7, 2026 | 01:56 PM
BigggT's Avatar
BigggT
Default New 12” Handle bars, Same riser torque?
Hi Guys,
Installs 12” KST Bison Bagger handle bars on 09 Ultra. Replaced stock riser bushings with urethane bushings from HD.
When sitting on the bike if i pull back on the bars they move a little (.25”, maybe .5” at most if i had to guess). Bars are not moving in the clamps I believe it’s riser bushing flex.
Bolts were torqued to HD spec from service manual.
Is this normal/acceptable? Should I have torqued to a higher value because of the higher bars and urethane bushings?
First time both installing and having higher bars so doing a sanity check on what’s kosher.
Attached a short movie clip showing the play.
Thanks in advance!
File Type: mov
Old Apr 7, 2026 | 05:34 PM
1TxBiker's Avatar
1TxBiker
Sorry but I don't need to download yer movie. Simple solution - tighten the riser bolts till movement is gone.
Old Apr 7, 2026 | 07:01 PM
BigggT's Avatar
BigggT
Ok so play is not normal and tighten beyond the stated HD torque spec until the play/movement is gone - got it. thanks
Old Apr 8, 2026 | 07:41 PM
Bass-M's Avatar
Bass-M
That movement is normal for urethane bushings. Don’t overtighten stick to HD spec. If you want zero flex, switch to solid aluminum bushings. Otherwise, ride it.
Old Apr 9, 2026 | 06:41 PM
BigggT's Avatar
BigggT
ok, so the play is normal because of the increased leverage of higher bars.lol sounds like i will need to back off the bolts I already intentionally overtorqued after this was posted - certainly dont want my riser
bolts snapping off while riding.
Appreciate the advice.
But i agree, i can’t see how there wouldn’t be any play with polyurethane bushings and 12” bars.
thanks again
(it anyone else wants to chip in feel free)
Old Apr 12, 2026 | 07:54 AM
kojak's Avatar
kojak
thanks again
You can have up to 1/4" movement from flex with the poly bushings. Over torquing over spec isnt going to make that go away (you can only compress so much with the inner steel sleeve in there), it can stress your bolts as you said and make the mount feel more rigid. You'll feel your hands going numb from the vibration as you ride. If the movement gets worse over time, just go back in there and retorque but with 12" bars, it shouldn't be a problem.
Old Today | 08:32 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Or the bolt snaps...
Over torquing the bolt is not the solution, on anything...
The bike does not have solid riser bushings so the increased leverage of the taller bars makes it easier to move the bars back and forth.
@BiggT
If the bolts were over torqued, they should be replaced.
Mattster
Mar 14, 2016 08:05 PM
apetterez
Oct 28, 2014 07:20 PM
XLsporty
Nov 10, 2011 07:45 AM
NoRegerts
Apr 13, 2011 02:01 PM
Mathews
Feb 8, 2011 02:40 PM
