2019 roadglide primary oil
Old Apr 21, 2026 | 04:57 PM
ultraglide12's Avatar
ultraglide12
Default 2019 roadglide primary oil
Just wondering my buddies 19 recommended primary oil is 80/140 so he got some from hd and was not happy 40 dollars for a liter and said it was 160 for filter,engine oil,primary from hd so he is thinking of changing brands what you guys using.i just use drag specialty primary oil in my twin cam but his calls for other
Old Apr 21, 2026 | 05:10 PM
GalvTexGuy's Avatar
GalvTexGuy
Start on the last page and work your way up from there.
https://www.hdforums.com/forum/oil-a...ur-choice.html
Old Apr 22, 2026 | 12:05 PM
ultraglide12
Thanx I did check that out it seems to be all over the map for different bikes. I was more interested in his 2019 m8 as harley had changed from what to use since the twin cam
Old Apr 22, 2026 | 02:38 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You can use the same lube in the primary for M8, TC, Evo.
Old Apr 22, 2026 | 02:44 PM
ultraglide12
Oh really ok that's weird they call for that heavy stuff . I will let him know thanx
Old Apr 22, 2026 | 03:08 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Don`t know who "They" are, but the lube that is specified by the 2019 service manual and the 2019 owner's manual is Formula +.
LQQK_OUT's Avatar
LQQK_OUT
Maybe just pick up a bottle of 10W-40 conventional oil, JASO MA2 rated like Valvoline 4-Stroke Motorcycle oil.
Valvoline 4-Stroke Motorcycle OIl
Old Apr 22, 2026 | 03:16 PM
Gomer's Avatar
Gomer
I like Shell Rotella T6 5w-40 in the primary. I think you'll find it pretty close to Harleys Formula+.
Old Apr 22, 2026 | 03:42 PM
NorthWestern's Avatar
NorthWestern
They do sell the 80w140 at the dealer, and there is nothing wrong with it. Works great.
He does not have to run it, it is just one of the options.
Old Apr 22, 2026 | 03:44 PM
Rounders's Avatar
Rounders
Has Harley changed its stance on 20w50 in primary?
