S&S carburetor it beats gasoline in reverse
Old Apr 26, 2026 | 05:24 AM
Banditezo's Avatar
Banditezo
Stage II
Default S&S carburetor it beats gasoline in reverse
Привет всем! У меня проблема с карбюратором. Думаю, я неправильно его отрегулировал, но когда я нажимаю на педаль газа, бензин попадает в фильтр. Можете подсказать, в чём проблема с моим карбюратором? У меня мотоцикл Dyna 2005 года с прямоточным выхлопом "Screaming Eagle". Жиклеры установлены на 0,072 и 0,0295. Фильтр оригинальный S&S. (Please don't judge me for my English, I'm from another country)
Old Apr 26, 2026 | 06:48 AM
FX WideGlide's Avatar
FX WideGlide
Hello everyone! I have a problem with the carburetor. I think I adjusted it incorrectly, but when I press the gas pedal, gasoline gets into the filter. Can you tell me what might be wrong with my carburetor? I have a 2005 Dyna motorcycle with a "Screaming Eagle" straight-through exhaust. The jets are set to 0.072 and 0.0295. The filter is an original S&S. (Please don't judge me for my English, I'm from another country)
Used Google Translate.
Old Apr 26, 2026 | 01:25 PM
John CC's Avatar
John CC
Sounds normal. Due to cam overlap, especially at cranking speeds and idle, part of the time air is being forced out through the intake valve. If it runs good, put the air cleaner back on and forget about it.
Old Apr 26, 2026 | 03:12 PM
tdrglide's Avatar
tdrglide
If it's just mist or a little wet, it's normal. Caused by exhaust reversion and valve overlap, normal. If it's dumping fuel then maybe carburetor float valve is stuck open
Old Today | 01:47 AM
Banditezo's Avatar
Banditezo
Stage II
Thanks for the advice, the problem was in the float chamber. I removed it, connected the gas, and adjusted the level. Before that, it was overflowing and a lot of gas was leaking from the main jet. Solved it. Everything's fine now.
BjornKenneth
General Topics/Tech Tips
Mar 13, 2025 02:26 PM
Hawg Runner
May 8, 2023 09:38 PM
Snyder191
Carburetor Related
Sep 3, 2018 05:58 AM
roadrunner68
Jan 31, 2011 03:39 PM
Roadkingfatboy
Jan 9, 2009 08:30 PM
