Prompt volume declines Skyline OS Infotainment
Old Today | 06:36 PM
GaBoyinSC's Avatar
GaBoyinSC
Stage I
Default Prompt volume declines Skyline OS Infotainment
On my 2026 Street Glide 3 Limited with the Skyline OS Infotainmentsystem I’m having an issue with the volume on the prompts dropping out when I’m using a head set. The headset volume does fine with calls and radio/music. When the gps gives me a prompt the volume falls down to nearly nothing. While the gps is speaking I can turn the volume back up. As soon as it is finished speaking that prompt the volume drops down again. This occurs when using the native Harley skyline on gps and it occurs when using Apple Maps and Google Maps in Apple car play. In Apple car play it also exemplifies the exact same failure when an incoming text message is being spoken. I have experienced these referenced failures using both a Sena 50s headset and a cardo pack talk pro headset. I’m sure someone else has experienced these exact same failures. Will someone please share what this fix is for these failures. This is frustrating as I have less than 400 miles on this so far. Has anyone else experienced this same issue? Were you able to fix it? if so, what was the fix? Thanks for your help!
RiderX
Jan 27, 2023 02:13 PM
ddeboo
Audio Systems
Jun 23, 2021 04:07 PM
solouncapitano
Audio Systems
Mar 12, 2020 02:45 PM
Smacker
Sep 26, 2019 09:54 AM
Motorcop540
Gear and Other Items For Sale
May 5, 2011 06:05 AM
