Twin Cam Motors Twin Cam 1998 thru 2017
Poor boy tuning
Old May 19, 2026 | 06:14 AM
xcbullet's Avatar
xcbullet
Default Poor boy tuning
Any help where to adjust on my PC3 would be great . 31mpg, 95 big bore MM
Old May 20, 2026 | 10:50 AM
xcbullet's Avatar
xcbullet
https://www.enginebuildermag.com/202...ur-spark-plug/
Finally found something on tuning by reading cut open plugs
Old May 23, 2026 | 05:59 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I'm assuming the left is front and right is rear??
Anyways how many miles on this build? The left one is good below approximately 2500 rpm but the midrange is a little rich with wot looking good.. The right plug is s little rich at idle and pretty rich in the midrange and wot.. It would also help to see the threaded part of of the plug with a top and side view of both..
Other than that I'm bet you have a heavy hand..
Old May 24, 2026 | 11:25 AM
xcbullet's Avatar
xcbullet
The left is rear. 40,000 miles on build. I just got tired of a small flat spot I couldn't get enough fuel to get rid of it. I just turned up the fuel pressure on it that changed everything. Almost think I should go carb
Yes like to twist the grip when alone.
I started from scratch on the front and after it looked pretty good on a ride, I did the rear in the same way. Will put some miles on before cutting open plugs again. Will included threads next, but they looked good heat range and timing looked ok, but looking at old plugs showing I could advance a cylinder some but not sure which one was what. So need to wait to get a good strap reading.
Curated Content Editor
Jan 5, 2024 08:36 AM
Ken45
Shovelhead
20
Apr 25, 2023 04:39 PM
