Start your Sportster 1200/883
You can't pack in more CCA then the maintenance charger does.
We have had a multitude of threads on the Sportster's battery size and starter.
Most do it.
Keep your bike well tuned, use the proper grade lubrication in it.
Just leave in on the maintenance charger. (0.75 milamp one)
Remember however occasionally after a few years to pull and have the charged battery load tested.
Only way to be safe since it is hard to know a battery is wearing out if it's alway on the maintenance charger.
Batteries kept that way have a tendency to get the last start leaving home.
My bike hesitates too, but I have a LFP battery. They supposedly need one stab of the starter button to "wake up" and the second push of the button turns over fine. Either way, my battery is almost six years old and has acted the same way since new. Like OC says, it's just the nature of the beast. I have a higher compression 1250 as well.
John
It's a Sportster thing. I don't think the 883s have the problem. I could be wrong.
John
Had my 2004 Softail 20 years. Now it was FI with the open loop, no oxygen sensors. Aways started and ran well from below 32F to 95F. Stock except a SE open box oil wet filter.
With a good battery, rarely was there a hesitation unless you turned it off from a hot fast run and fired it back up like after a gas stop.
It would hesitation till it clear one cylinder probably and then firing on both cylinders took the load off the starter.
As the battery wore out of course, hesitation became way more noticeable and sometimes banged the starter with a kick back. I knew immediately it was new battery time.
Another trait was you didn't dare hit the starter and let up.
On the FI, if you did that, you had to crank the second time holding the throttle open slightly to let air clear it or it would not start.
I replaced the original starter with a higher kw model, but really no change.
I also changed the clutch shell ring gear and pinion gear from 9/66 to 10/84, still didn`t cure it.
Once it gets past the initial compression stroke it cranks over fine and starts quickly, I just don`t like that initial starter stall at the first compression stroke.
I figure that the 180psi cold cranking pressure was a struggle for the starter.
I had compression releases installed in the heads, in process of reassembly now.
We will see...
