How to fill this void?
Old Yesterday | 06:06 PM
Spec4's Avatar
Spec4
Default How to fill this void?
2002 wide glide,I put 13.5" shocks on and need to close this up. I have garage door weatherstripping for one idea. I also saw a new gasket on ramjet racing,but idk if it would add any height? Anyone have suggestions please? Actually,i wonder if i shoukd upgrade those shocks,i bought them from fb and they were Re-worked but Never used,only thing is it was 20 yrs ago,they have Stiff resistance but it feels like they're Hard or something when i hit a big bump.Thanks 👍
Old Yesterday | 06:27 PM
Rounders's Avatar
Rounders
Great stuff or leave it alone. I would leave it alone. Anything you do will probably be worse and a waste of time. No one sees this as issue but you
Old Yesterday | 06:59 PM
Max Headflow's Avatar
Max Headflow
Remove the taillight, cut a piece of sheet metal to fit using the tail light mounting holes and paint black.
Old Yesterday | 07:18 PM
Spec4's Avatar
Spec4
I was concerned about water,etc. getting in and out around there,thought it could turn into some type of issue in time. All good, appreciate it fellas!
Old Yesterday | 07:34 PM
Addicted to Chaos's Avatar
Addicted to Chaos
Sounds like the shocks are ****. What brand and can they be rebuilt or do they need to be replaced with something that works?
Water shouldn't be a huge issue, it is pretty waterproof but yeah you should probably put something in there to button it up. What pipe are you running, the stock pipes wouldn't work with a 13.5" shock?
Old Yesterday | 07:35 PM
Rounders's Avatar
Rounders
You will be going forward most of the time . What is under there that could be water proofed or needs to be?
Piece of black hose maybe tywrapped underneath to hold in place
Old Yesterday | 09:01 PM
Max Headflow
Water is getting in no matter.. Best thing to do is keep it from building up anywhere.
miky2001
Touring Parts
Mar 12, 2024 04:25 PM
Sedonastrider
Dyna Parts
Jun 8, 2022 11:19 PM
b1gj0n44
Mar 7, 2019 10:33 PM
kurtzimmi
Sep 23, 2007 08:46 PM
