Tight Clutch 90 Sportster
Old Jun 5, 2026 | 09:35 PM
Vza's Avatar
Vza
Default Tight Clutch 90 Sportster
Hi All, Replaced clutch cable and after adjustment behind derby cover and on the cable to pick up the slack the clutch is pretty tight when squeezing almost feeling it isnt pulling anymore. I backed out a bit on clutch adj bolt( behind derby cover) but didnt seem to help much. Play seems ok at clutch lever and its shifting fine. Just hard to pull. Thanks
Old Yesterday | 05:03 AM
chopper_man's Avatar
chopper_man
Start with why the cable was replaced to begin with? Was it originally tight? If not, my guess is, it's either your cable routing or **** cable.
Old Yesterday | 09:48 AM
Vza's Avatar
Vza
I mistakenly trashed the old cable broke the seal at primary cover end when replacing primary gasket. New Milwaukee Twins cable, same length as old cable, routing straight up from cover pretty much. I have it zip tied to the speedometer cable. Old cable was fine. .
Old Yesterday | 08:48 PM
John Harper's Avatar
John Harper
Have you lubed the new cable? Is the cable end connected to the ramp and ball assembly correctly? I know you have to pull the primary cover to check it, but hopefully lubing the cable helps.
John
Old Today | 12:32 AM
Vza's Avatar
Vza
I didnt lube the cable but...after installing everything I misplaced one the clutch pin bushings (where the cable attaches up on handle bar)so I layed the cable on the floor and the next day there was primary oil all over the garage floor...I believe the oil seeped up the cable and leaked out. Maybe I should try readjusting the clutch from under the derby cover. I may have snugged the bolt too much before backing off 1/4 turn.
Lromine1997
May 24, 2020 05:52 PM
Grilljames
Jun 17, 2015 08:14 AM
hyde316
May 15, 2015 11:24 AM
Dangermouse
May 30, 2013 07:04 AM
Wally
Jun 5, 2010 08:00 AM
