Electrical Issue after bike is warm.
Old Jun 8, 2026 | 01:23 PM
motoman247's Avatar
motoman247
Default Electrical Issue after bike is warm.
I am having a problem with my 1996 Ultra. Whenever the bike gets hot it randomly looses all power and the bike shuts off and backfires. This is mainly happening after it is first cranked up after being ridden and I go to put load on the bike and it shuts off and backfires. I crank it back up and it wont do it again unless I ride it really hard and come off the throttle quickly to slow down, then I loose all power (radio, gauges etc) and the bike shuts off. I am able to immediately bump start it or use the starter without touching anything else on the bike.
This started happening at Myrtle Beach and I observed the voltage output to only be right at 12. So i just replaced the stator and regulator and put a 50 amp main circuit breaker in there. I have the wire coming from the stator and the wire going to the fairing on the silver lead and the other wire for the battery/starter on the brass lead. Also before Myrtle I changed all fluids and replaced the air filter with a new one.
Bad coil? ignition? New air filter causing it to run lean? I wouldn't think that would cause the entire bike to loose power.
Any ideas?
Picture of the bike just because.
Old Jun 8, 2026 | 03:05 PM
Max Headflow's Avatar
Max Headflow
2 places I'd look is the ignition switch and the circuit breaker terminals.
If the circuit breaker terminals have poor crimps, they can heat the breaker and cause it to trip. Best to lop them of and replace with new. I typically crimp and solder them.
The ignition switch can become flakey and open up. On a 96, all the power is routed through the ignition switch.
Old Jun 8, 2026 | 05:27 PM
motoman247's Avatar
motoman247
Thank you, I will check there, my ignition switch has always been weird.
Old Yesterday | 05:52 AM
98hotrodfatboy's Avatar
98hotrodfatboy
For ***** and giggles pop the cover off the cam chest nose cone and check to see if the cam position sensor is leaking the "Brown Goo"
Old Yesterday | 06:31 AM
touchdown's Avatar
touchdown
Also check the battery had one that did the same thing and it was the battery. when it happened I did go over all of the connections too. How I found out was I took a battery out of another bike and tried it and it worked.
Old Yesterday | 06:44 AM
Rains2much's Avatar
Rains2much
Last remove the main battery to frame ground.. don’t care if it seems good and tight.. remove it. Clean it thoroughly down to raw steel. Re-fasten it nice and tight.
Check all of the leads between the battery and the starter. This is in addition to all the other suggestions you’ve had. They all seem like good suggestions to me.
I’ll share with you my personal embarrassment and mortality. My 90 that was stolen. Absolutely gave me ghost fits. Every once in a while it would cut out other times during acceleration would act weird. It had so many strange symptoms. I couldn’t put my finger on whether it was timing or fuel. I spent a lot of time in frustration trying to fix it. The battery terminals were like brand new and felt super tight. So I never remove the main ground right under the seat on that softail. One day for whatever reason I removed that ground and I went ahead and cleaned it and put it back. All the problems went away. It was that simple right in front of me. The bike only had 6000 original miles on it and that cable was super tight and in perfect condition. There was no reason for me to think that it had anything to do with the ground shorting there.
Old Yesterday | 09:12 AM
Sportfisher23's Avatar
Sportfisher23
When I move my bars all the way to the right on my FLHS, the high beam flickers on. I'll just go straight.
Old Yesterday | 10:59 AM
Rains2much's Avatar
Rains2much
You got a bad connection that’s going to ground
Old Yesterday | 07:24 PM
carlgrover's Avatar
carlgrover
I had a battery cable issue like this not long ago. Check all the connections, not just the battery connections. It won't hurt a bit to put a star washer on the frame ground connection. It will bite into the frame better that way.
carl
Old Today | 06:20 AM
Architect's Avatar
Architect
My friends father like to say, "it is always the ground". Good luck.
HolyRider
Electrical/Lighting/Alarm
11
Jul 11, 2024 03:59 PM
2012SG_Man
Feb 27, 2023 11:13 AM
jve
Shovelhead
Aug 17, 2022 03:03 PM
Vol_Dad
Jun 11, 2014 05:47 PM
Tunernetwork
Jun 9, 2011 02:12 PM
