Navigate on the touchscreen to Menu > Settings > System > System Info, then select Factory Reset.
I know that factory resetting erases everything, but I wanted to avoid it so as not to lose all my settings. Although I'm increasingly reading that it's a good idea to do so, especially when there are Skyline updates.
You can "forget" "delete" a network without factory reset. You actually have to touch the wifi you want to delete with your finger to get the prompt.
I tried to do as you said, but nothing happens, it just tells you that it is not possible to connect to that network if it is not available at the moment. But it does not let you forget it or unassociate it.
