Sportster S Sportster S Only
Fault code
Old Jun 19, 2026 | 02:34 PM
JohnSparky's Avatar
JohnSparky
Default Fault code
Hi, I’ve noticed a yellow triangle on my dash twice now. Once engine turned off then back on again it disappears. I went into the diagnostics and the fault code is B116609C. Any ideas? The bike drives perfect with no dodgy noises .
Old Jun 19, 2026 | 04:03 PM
chopper_man's Avatar
chopper_man
Right hand switch pack. Specifically a run switch fault. Start with cleaning it (off the bike) with a quality electronics cleaner. You can be brake and do it on the bike but disconnect the battery and cover everything around it. If persits, replace the pack.
Old Jun 19, 2026 | 04:15 PM
JohnSparky's Avatar
JohnSparky
Mmm I’ve just had this right hand switch pack replaced under warranty due to the key less start not working. I’ll check all connections and see if it does anything. Thanks for the fast reply
Old Today | 12:54 AM
JohnSparky's Avatar
JohnSparky
So I went out on the bike yesterday but before I did I checked all the wiring connections on the right hand switch pack to make sure everything was ok and nothing loose. All seemed ok but gave everything a push into its rightful place just in case there was a loose connection and no warning light now on first start up so hopefully a push in connector that wasn’t quite pushed in right.
UALCapt
2014-2024 Touring Models
15
Sep 12, 2018 10:23 AM
Steve Bokowski
Jul 8, 2018 10:28 AM
Road Hawg
May 10, 2018 02:33 PM
drive1450
Feb 4, 2017 10:55 PM
karim.samir
Dec 13, 2014 09:53 PM
