I have a 2026 Road Glide Limited that I want to install a radar detector on. What do I need to do to connect the radar detector’s power cord to this accessory connector under the seat?
Thanks, but I’m looking for a plug and play option…not willing to cut any of the oem wiring.
Well, from the looks of that pigtail you'll have to run wires from the middle/back of the bike up to the headlight area. It means pulling the tank and adding a wire along side if others.
You could try and find a plug for the connector that is mounted on the end of the position light. I suspect it's going to be a bulb. Maybe someone makes one for LED lights that could be fit there?
I added a GPS to the my RK. The wires were there and I had factory style CAN bus connectors. I simply used them..
