rear fender light on breakout...and license plate relocation
ok....I know this has been covered here plenty of times...but after spending a day searching for diagrams and actual wiring information, I am a bit lost.
I got everything taken apart and figured out how to take the wires out of the plugs and got the new turn signal standoff on order. that part will be ok. my questions...
Can I wire the LED license plate bolts into the plug where the original bracket was plugged into? Can I reuse the original sleeves or would I need new ones?
Second question...The under fender light needs to be hooked up, but I don't know where to tap or how to do it without cutting anything up. I've seen pictures, but without an explanation I don't really understand it.
I want to make sure I understand what I'm doing. Wiring and electrical has never been my strong suit, but I'm willing to try and have a very basic understanding. Just don't want to screw anything up...and I actually take pride in doing these things myself.
I'll post up pics when I'm done....also putting on a bowman sissybar...so the wife can come along once in a while.
as always...thanks for all the help
ok...so i decided that I'm going to buy a new plug and wire the LED bolts to it and plug it in to the oem plug on the bike for the license plate lights. I'll run them up the swing arm. Figure that shouldn't be terribly difficult and a novice like me should be able to do that.
Now...I need to tap into the brake lights to wire up the led brake light strip.
Can anyone identify these wires? I've looked and as I don't have a wiring diagram I don't know what each one is. I really only need it as a brake light. That's the plug from the left hand side turn signal.
musclehd
07-06-2017 08:23 AM
