Lowering a softail
Old Apr 20, 2015 | 10:56 PM
jcapps's Avatar
jcapps
Default Lowering a softail
I am sure there are threads but could not find one asking this
Just bought an 04 Deuce. Looking to lower it two inches in the rear and maybe 1.5 in the front
What are the opinions on the best method and best products for the method you chose, to drop the front and the rear
Thanks
Old Apr 20, 2015 | 11:45 PM
Steven725's Avatar
Steven725
Thanks
The Progressive drop in kit is probably best bet for the front. For the back you can do air ride or bolts just depends on how much you want to spend. Blots are super cheap compared to air ride.
Old Apr 21, 2015 | 06:59 AM
dyolfknip's Avatar
dyolfknip
Thanks
You have 1400+ posts and you cant find the one that talks about lowering a softail?
Here you go: http://lmgtfy.com/?q=lower+softail+h...w.hdforums.com
Old Apr 21, 2015 | 07:06 AM
Bluraven's Avatar
Bluraven
Good response.
Front- progressive drop-ins
Rear- Progressive 422s or Shotgun shocks.
Old Apr 21, 2015 | 07:24 AM
Village Idiot™'s Avatar
Village Idiot™
With bolts you'll probably have to set the stock suspension to it's stiffest to avoid bottoming out and then it gets rough.
My Deuce in my sig has a shotgun air ride shock slammed and a 2" lowering spring kit up front.
Old Apr 21, 2015 | 09:00 AM
jcapps's Avatar
jcapps
silly me. I was searching using the forums search feature. Every possible thread came up and 99% were not about lowering
Works well when you leave the forum and google the forum, learn something new everyday
thanks
Old Apr 21, 2015 | 10:04 AM
bikerlaw's Avatar
bikerlaw
Progressive drop in kit for the front, and lowering bolts for the rear. Under $150 delivered. The bolts, though super cheap, require disassembling the shocks which is a total pain, and an expense if you can't do it yourself. Any shop will do it for 50 bucks (or less). Otherwise, pony up for air ride or 422's. Either is an excellent choice.
Old Apr 21, 2015 | 10:30 AM
gatorfrey's Avatar
gatorfrey
I got a deal on a pair of new 422s. I got them to lower the bike 2 inches.
On the day I went for a test ride, it was noticable how much smoother the 422s are!
They are worth the money.
Old Apr 21, 2015 | 10:50 AM
WanaRyd Wheels's Avatar
WanaRyd Wheels
Sponsor
We offer progressive lowering kits if you'd like to check our website out!
If you'd rather call we are all more than welcome to help you out, mention you are a HD forum member to save some bucks!
__________________
WanaRyd Motorcycle
1-888-926-2793
Old Apr 23, 2015 | 10:15 AM
ADRENALINE RUSH's Avatar
ADRENALINE RUSH
it really depends it you car about the stiffness of the suspension... comfort of the ride...
if you don't care, use progressive drop-ins for the front and lowering bolts for the back (you will loose travel and have a much stiffer ride). if you do care get new / used fork tubes that shorter from the factory made for another softail or DBI fork tubes, that way they will be lower with out loosing any travel and get air suspension like shotgun or other brand (you will not loose travel and maintain that comfy cushy ride).
41 mm Tubes
FLT 1984-1996 20-7/8"
FLT 1997-later 20-1/4"
FLSTC/N/F 1986-1999 22-7/8"
FLSTC/N/F 2000-later 22-1/4"
FXWG ,FXST/C 1984-1999 24-1/2"
FXDWG,FXST/C 2000-later 24-1/4"
Edit: there are higher end lowering kits that will give you that stock feel with less travel loss, but the above is my personal opinion
