I Have A Noise In The Rear Wheel Area On The Belt Side
On my 2011 Fat Boy Lo I first noticed a slight "chirping" noise in February when we were on vacation in New Smyrna Beach, we were staying right on the ocean and I thought it may have been the sticky salt water mist on the pulley (and all over the rest of the bike) that was in the air because as soon as I washed the bike it cleared up. Now the noise is back and more pronounced, just washed it up a couple of weeks ago, so I don't think it's a dirt thing, but on our ride up to Sandusky the weekend before last it never seemed to go away.
Now I'm starting to think wheel bearings. Could it be the belt working around in the pulley, if it wasn't completely true or the belt tension was off? The wheels are from Extreme Machine and have only been on for 2000 miles tops. Has any one had trouble with their wheel bearings? If I do replace the bearings, what are you guys using? Are OEM worth a ****? Are there some better aftermarket options? I've always preferred Timken or Link-Belt when I can get them
That was one of the things I'm going to check when I service it this week. With the Shotgun Shock it changes with changes in ride height. Another variable
The pulley isn't showing any kind of wear like the belt is walking around though
Any of these might lead you to different answers. I seem to be experiencing #3 which would imply bearings... that have to get hot first... or my ears don't work first thing in the morning. Problem is I had my bearings replaced a while back and they should still be good. I am getting ready to put on a new rear tire so I will know more once I have done that.
Good luck... love those Harleys.
C#
I don't slam my Shotgun Shock to the ground, adjust the belt and then raise it to riding height when I leave.
