Rear Belt Pulley Bolts broke loose...WTF
Subscribe
Jun 29, 2015 | 10:19 AM
Bolts loosen!
I just installed a new rear tire on my 2000 Nightrain & while I was at it I checked the Sprocket bolts & some were tight, some not so tight.
Here's the cure for those aluminum wheels... Purchase "Time serts!"
They work like Heli-coils but are solid, not springy!
While your at it, buy 10 (Plus install kit) it will give you enough to do the Disc brake rotor too!
>Kits comes with short inserts, but I ordered 1-1/2" in length (7/16"- 14).
Reply 1
Jun 29, 2015 | 10:36 AM
At how much was put in bike, did the dealer install chrome bolts? I have see a few of these on here (probably a dozen in the last few years) but they are usually from bikes that have been changed over to chrome bolts. I seriously doubt a mechanic does little more then look at locktite held fasteners. You sure do not try to turn them and there is really no need to if they are up to the face.
Not sure if you have removed a permanent loctited fastener on the footpegs, rotors or drive pulley but when done correctly, they are a real bear to get off without an impact or heat. There should be some trace of loctite at bottom of hole. Are the other's tight? If so, and are are the OEM bolts from the factory, they must have missed the loctite.
Reply 0
Jun 29, 2015 | 01:02 PM
Quote: At how much was put in bike, did the dealer install chrome bolts? I have see a few of these on here (probably a dozen in the last few years) but they are usually from bikes that have been changed over to chrome bolts. I seriously doubt a mechanic does little more then look at locktite held fasteners. You sure do not try to turn them and there is really no need to if they are up to the face.
Not chrome bolts, still stock.
Reply 0
Jun 29, 2015 | 01:20 PM
Dealer is trying to get out of doing it under warranty, because they don't believe I checked the torque and they did not do the service ... MAJOR B.S. ... There ain't a "tech" out there that checks the torque of pulley/rotor bolts ( or for that matter, just about any of the other fasteners ) and if they did ( as others have stated) they'd have to get around the Loc-Tite factor ... It becoming a standard response, "the warranty doesn't cover that" or "they all do that" ...
Reply 0
Jul 1, 2015 | 06:16 PM
Got the bike back today. Quick turn around even though today is a holiday here.
All done under warranty. Bolts and pulley replaced. Broken bolts removed from rim and rim is OK. Put 100 kms on it on the way home and had it up to 130 kms/hr with no wobble or vibration.
My dealer came through with great service from the Techs and quick turn around.
Now I have to ride the hell out of it to make sure there are no issues before I go on my road trip next week. More so for my own piece of mind.
Reply 0
Jul 2, 2015 | 04:16 AM
Nice, all's well that ends well I guess. I know I have checked mine just because of this thread.
Gary
Reply 0
Jul 2, 2015 | 06:03 PM
Quote: Got the bike back today. Quick turn around even though today is a holiday here.
do yourself a favor and hash mark all critical fasteners. I used a med point sharpy marker and put small hash marks on bolt heads and surface that bolts are supposed to hold together. all it will take in the future is a quick glance to see if the marks still line up. if they're lined up you know they're tight.
Reply 0
Jul 2, 2015 | 08:42 PM
Quote: do yourself a favor and hash mark all critical fasteners. I used a med point sharpy marker and put small hash marks on bolt heads and surface that bolts are supposed to hold together. all it will take in the future is a quick glance to see if the marks still line up. if they're lined up you know they're tight.
Good call, I will do that when I go over it top to bottom this weekend before my trip.
Reply 0
Explore
Jul 2, 2015 | 10:08 PM
just assume everything is OK with your bike (of any age)
Never check anything, if something comes loose , then blame someone else.
Reply 0
Jul 2, 2015 | 10:20 PM
So in my case would you expect those bolts to be loose with less than 500 miles on a brand new bike? I'm not very trusting person but if I buy a new bike and have it less than 2 months I don't expect all the bolts in a major component of the bike to come loose. I don't know call me crazy..
Reply 0
