Threads Stripped PLEASE HELP!!
Old Aug 11, 2015 | 06:25 PM
smgallagher82's Avatar
smgallagher82
Default Threads Stripped PLEASE HELP!!
I just got some 41mm quick detach clamps in the mail yesterday. I just bought some bolts today for them, but the bolt stripped the threads on the locking clamp. The bolts worked perfect for the other three clamps. Can anyone tell me what the thread is supposed to be for the locking clamp, if its different from the others?
Old Aug 11, 2015 | 09:28 PM
racerkvn's Avatar
racerkvn
I know I'm not much help as I have no idea what clamp you're referring to but if you have some calipers, measure the bolt diameter and then count the threads per inch. If its a standard imperial bolt it'll be a standard size like for instance 5/16"-18 or 5/16"-24 (.312" diameter 16 or 24 threads per inch). If its a metric bolt it'll measure for instance, .315" diameter which is an 8mm or M8 bolt. The threads are alittle different on metric hardware but by figuring out the diameter you can search for the pitch.
Old Aug 11, 2015 | 11:18 PM
Gommee's Avatar
Gommee
Devil's Advocate
Pictures of the clamps will help understand what you did and what you are looking for.
Old Aug 14, 2015 | 11:46 AM
smgallagher82
Used a 5/16-24x1 bolt like i did for the other picture.
Fit like a glove on this one and the other two.
Old Aug 14, 2015 | 11:49 AM
RandallJ's Avatar
RandallJ
Going to need a thread repair for sure..
I prefer "Timeserts" but helicoil should work just fine.. Seem to have plenty of meat around the hole so go at it..
Old Aug 14, 2015 | 12:37 PM
smgallagher82
That's what i may do, but was hoping that someone would know off hand what the diameter and thread count was. Reason being that if what i used was indeed correct, i was sent a defected clamp and going to return for replacement. Otherwise I'll have to repair and used slightly larger bolt.
Old Aug 14, 2015 | 12:54 PM
smgallagher82
This is what I'm putting it on.
CrackHeadBob
May 8, 2016 10:44 PM
shaker
General Topics/Tech Tips
Nov 8, 2013 08:04 PM
cjlandry
Jul 28, 2011 02:47 PM
Steeler
Feb 12, 2011 03:08 AM
freshman
Jun 15, 2010 05:12 PM
