Slim S
Old 09-11-2015, 02:05 AM
paullavery's Avatar
paullavery
paullavery is offline
Default Slim S
Just wondering what options are available for slip on mufflers instead of the stock ones ?
Old 09-11-2015, 04:42 AM
Loonie's Avatar
Loonie
Loonie is offline
I assume you wanna go black instead of chrome? If it's the case there in at least 3 options:
http://products.vanceandhines.com/st...softail/46841/
http://www.harley-davidson.com/store...hrome-64900335 (available in black)
http://www.rushracingproducts.com/so...luxe07_12.html
May be there is a lot more but I'm going with V&H .Do some research on the forum and you'll find parts that will suit you.
Welcome in the club!
Cheers
Loonie
Old 09-11-2015, 05:50 AM
paullavery's Avatar
paullavery
Cheers Loonie, definitely Black !
I'll check out the links, can't wait to get mine.
Cheers, Paul.
Old 09-11-2015, 07:53 AM
uklauren's Avatar
uklauren
uklauren is offline
Florida Crew Moderator
Received 3,389 Likes on 1,560 Posts
I have been looking for mufflers for my Fatboy S. I haven't chosen any yet but I did look in some catalogs, V & H, Arlen Ness, etc. I'm still not decided. I think Kuryaken make some that fit tho I'm not crazy about their products.
Old 09-11-2015, 09:19 AM
mofomojo's Avatar
mofomojo
mofomojo is offline
Do the slip-ons generally require a re-tune?
Old 09-11-2015, 02:08 PM
paullavery's Avatar
paullavery
I think its only necessary if you change the headers & the intake but i'm sure someone more knowledgeable will be along to confirm or correct me.
Old 09-11-2015, 02:13 PM
SLV's Avatar
SLV
SLV is offline
Normally, if you add slip-ons only, you can get away without a new tune, but HD motors are already tuned lean from the factory, so you'd just be leaning it more. The ECM can make adjustments on its own, and a lot of people say it can compensate for exhaust or intake, but not both at once.
The S-Series bikes already have a high-flow intake (in fact all the models with the new HO 103 do too.) In theory, just adding slip-ons to the S-Series bike should only be a minor adjustment and the ECM should be able to handle it.
I prefer to tune it simply because it is tuned lean and will likely still be lean after ECM makes any changes.
Old 09-11-2015, 02:15 PM
SLV's Avatar
SLV
SLV is offline
That would be true for a touring bike, Wide Glide, Fat Bob or other bikes that have the catalytic converter in the head pipes. The Slim has the cat in the muffler, so stock or new head pipes don't make much, if any difference (unless they are large diameter, then some difference would exist.)
Old 09-11-2015, 02:37 PM
paullavery's Avatar
paullavery
So by changing the stock mufflers we will get rid of the catalytic converter which in my opinion is a good thing, what replacement mufflers would you think are a good option for the slim s ?
Old 09-11-2015, 03:53 PM
SLV's Avatar
SLV
SLV is offline
Default Slim S
There are a few options in black and a few more in chrome.
Vance and Hines
Python
Two Brothers Racing
Rush
Crusher
Quick Reply: Slim S
