Crankcase Pressure
Old Feb 17, 2016 | 04:19 PM
Mike Lawless's Avatar
Mike Lawless
The two big bolts that attaches the air cleaner housing to the heads. Those should hollow
Old Feb 17, 2016 | 05:23 PM
Pitbull_Dallas's Avatar
Pitbull_Dallas
Thanks, I'll have a look at them..
Old Feb 17, 2016 | 06:32 PM
1004ron's Avatar
1004ron
Originally Posted by Pitbull_Dallas
Where on the rocker boxes are the vents? I'll check them out if I know where to look..
You should consider buying a service manual.
Old Feb 17, 2016 | 07:13 PM
Pitbull_Dallas
Boy, talk about an overly complicated design just to vent crankcase pressure. Thanks for posting that!
Old Feb 19, 2016 | 08:34 AM
eksofttail's Avatar
eksofttail
check the two breather tubes coming off of the rocker boxes they might be clogged
Old Feb 23, 2016 | 01:08 PM
1004ron's Avatar
1004ron
You're welcome - did you find the cause and get it sorted?
Old Feb 24, 2016 | 12:37 PM
Pitbull_Dallas
Nope and I've looked and checked everthing. All seems to be as it should. I haven't and don't want to go into the rocker boxes..
Old Feb 24, 2016 | 05:56 PM
Campy Roadie's Avatar
Campy Roadie
That's the only way to definitively check the rocker box breather system. Gotta raise the upper cover and unbolt the breathers. It's an 08 it has the older style plastic breathers.
Old Nov 20, 2024 | 06:12 AM
airjordan23's Avatar
airjordan23
Stage I
Default Did
whatever did you did out!?
QUOTE=Campy Roadie;14877480]That's the only way to definitively check the rocker box breather system. Gotta raise the upper cover and unbolt the breathers. It's an 08 it has the older style plastic breathers.[/QUOTE]
Old Nov 20, 2024 | 04:17 PM
YZR's Avatar
YZR
Huh???
