Are Speedometer Problems Common With Softails
Old May 9, 2016 | 08:40 PM
motohaid's Avatar
motohaid
Default Are Speedometer Problems Common With Softails
I just acquired an '06 Fatboy about a month ago. I have only put 500 or so miles on it and the speedometer stopped yesterday. The odometer still works. When I turn the switch to the accessory position it turns all the way to 120 mph and slowly drops back to 0. I was wondering if the Softail models and the Fatboys in particular are known to have speedo problems.
Old May 9, 2016 | 10:03 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I've never had a problem with mine but mines not 10 years old either.
Old May 9, 2016 | 10:14 PM
Pete3323's Avatar
Pete3323
No but gas gauges are....
Old May 9, 2016 | 10:15 PM
the blob's Avatar
the blob
Pull the speedo sensor on the trams. Might have gunk built up on it.
Old May 9, 2016 | 10:34 PM
Clammy's Avatar
Clammy
Reaper is an '05 Night Train. She has over 107,000 miles on her, and her speedo has always functioned just fine.
Cheers!
Old May 9, 2016 | 11:43 PM
SPRINGER's Avatar
SPRINGER
No problems with my 05 Springer, I've had her for 11 years and with over 96k on her and all my gauges work perfectly.
Old May 10, 2016 | 06:32 AM
greybeard122's Avatar
greybeard122
Never had a problem with my 05 Nightrain and that had 30k on it when I traded it in. If the odometer works, its not the speed sensor.
Old May 10, 2016 | 07:49 AM
ChromeJunkie's Avatar
ChromeJunkie
I have a 2005 Softail Standard with 22k on the clock. Never an issue with the speedo. Fuel gauge a different story. I also have a 2006 Heritage Classic with 88k on it without a speedometer issue. No fuel gauge issues on this one.
Old May 10, 2016 | 07:51 AM
E8USMCRET's Avatar
E8USMCRET
02 Softail, no issues. Got rid of the broke dick fuel gauge years ago.
Old May 10, 2016 | 07:53 AM
Jackie Paper's Avatar
Jackie Paper
Mine (2004 with 50K) has never missed a beat but the tac is crazy above 3000 in cold weather like it sticks and jumps at 1000 leaps back and forth.. They are servo motor driven by digital input. I would pop the console off and pug and unplug it. Bet that is all it is. Could be the sensor but I doubt it. They do get metal on the pickup and act up however.
