Front End Clunk Fix
Old May 30, 2016 | 08:49 AM
tigercreek's Avatar
tigercreek
Default Front End Clunk Fix
For something that was so easy to fix it sure was hard to get the correct information.
The following will remove the mystery - a simple fix/procedure.
The fix covers -
• 2006-2007 Dyna models
• 2008 and earlier FXDWG
• 2008 and earlier FX Softail models
• 2008 and earlier VRSC models
In a nutshell, remove the steering stem nut, bend back and remove the tanged washer.
Replace the tanged washer with a new smooth, hardened washer 45727-08.
Replace the nut and torque to 70-80ftlbs.
Done.
Here are some pics along with the two TSBs I couldn't find.
The steering stem nut and tanged washer.
Bend the washer flat to remove the steering stem nut.
Replace the tanged washer with 45727-08 - purchased through HD.
The new smooth washer and the tanged washer. The new washer with the 70-80ftlbs torque spec removes the clunk.
TSB
Detailed TSB
Old May 30, 2016 | 11:23 AM
JeffJA's Avatar
JeffJA
thanks!
did you "have" to re-set your fall away after this?
Old May 30, 2016 | 11:37 AM
skid_pimp's Avatar
skid_pimp
Nice!
Old May 30, 2016 | 11:47 AM
tigercreek's Avatar
tigercreek
Originally Posted by JeffJA
thanks!
The instructions suggest checking your fall away.
Sootylad
Oct 17, 2015 03:08 AM
m i k e
Aug 4, 2012 12:01 AM
JRK5892
Jul 14, 2012 10:27 PM
m i k e
Jul 19, 2011 04:22 PM
bubbas1
Dec 24, 2006 06:47 PM
