Grinding Noise
Old Jun 19, 2016 | 04:02 PM
johncole's Avatar
johncole
4th Gear
Default Grinding Noise
I have a 2009 softail 103 ci. When I let out clutch in neutral, there is a grinding noise. The noise is still there when I pull clutch in until I rev it up . Would like to avoid a trip to the shop...just bought it and my wife already isn't real happy.
Old Jun 19, 2016 | 05:08 PM
QC's Avatar
QC
Drain the fluid, pull the cover and have a look-see.
Old Jun 19, 2016 | 06:06 PM
johncole's Avatar
johncole
4th Gear
I have I did not see anything that caught my eye . I have adjusted the clutch some improvement but not much
Old Jun 19, 2016 | 06:10 PM
QC's Avatar
QC
Anything unusual on the drainplug magnet?
Old Jun 19, 2016 | 06:31 PM
johncole's Avatar
johncole
4th Gear
No service all three hole all looked good.I adjusted clutch 1/2 turn back . Do you adjust to a full turn back
Old Jun 19, 2016 | 06:33 PM
QC's Avatar
QC
1/2 turn max.
Are you noticing any cluch slippage or other performance issues that might be related?
Old Jun 19, 2016 | 06:39 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Engine running, transmission in neutral, clutch lever released, you hear the noise.
Pull in clutch lever, you hear the noise.
Drop transmission into 1st gear, noise stops.
Does that description fit?
Old Jun 20, 2016 | 12:05 AM
balloo's Avatar
balloo
When my 2008 Heritage did this, it was a bad Compensator and inner primary bearing.
Old Jun 20, 2016 | 09:35 AM
Sarah93003's Avatar
Sarah93003
I can't stand it! Every time I read this title I am reminded of those little bells you put on tricycles that go "Gring, Gring" when you flip the lever.
Old Jun 21, 2016 | 11:47 AM
johncole's Avatar
johncole
4th Gear
Pretty much in neutral if I rev it up after pulling in clutch it stops
