Burly Slammer Question
Old Jul 5, 2016 | 10:09 PM
HighonHarley's Avatar
HighonHarley
Default Burly Slammer Question
I'm trying to decide between a Burly Slammer kit or a softailloweringkit.com rear set up. Any pro/con about these? Also, is there an easy way to install the Burly? The website says you need some kind of shock compression tool
Old Jul 5, 2016 | 10:36 PM
jtarter's Avatar
jtarter
I don't know anything about the Burley kit, but I installed the softaillowering kit. It was simple. No compression tool needed, but you will need to be able to raise/lower rear wheel. As far as the ride goes, the rear suspension is non-existent. I lowered 2" in the rear. I do like the way it looks, but will eventually go with Shotguns.
Old Jul 5, 2016 | 10:49 PM
HighonHarley
sounds like softaillowingkit it's not really worth it then. Thanks for the heads up
Old Jul 5, 2016 | 11:39 PM
hdpearson13's Avatar
hdpearson13
Have burley sits nice but will eventually figure out a better setup. like a airshock and much better seat. a 14 inch rear wheel with very low pressure tires and skidguards have crossed my mind as something's to look into with the burley kit and stock shocks. I've ruined a set a street sweepers and d&d fat cats. i lowered my front also made a better ride after lowering the rear. I have been keeping an eye out for a setup I can raise and lower depending on the terain.
dencor
Jan 31, 2016 04:48 PM
redneckharley
The Dark Side
Mar 24, 2014 09:20 PM
rkcmike63
Sep 1, 2013 06:28 PM
Iron lHorse
Jun 2, 2011 10:17 PM
Memo7070
Nov 16, 2009 09:26 AM
