HELP! Need Wiring Diagram 2001 Heritage FLSTCI
Old 07-07-2016, 08:42 PM
Bender4's Avatar
Bender4
Bender4 is offline
Stage III
Default HELP! Need Wiring Diagram 2001 Heritage FLSTCI
Hi guys, I am in need of a pic of the wiring diagram for a 2001 Heritage Softail EFI. I needed to change out the fuse blocks which went well. All works fine except I can now start the bike in ACC. I must have flip flopped a couple of wires. I have found some pics on line but I cannot zoom in well enough to read them. What I specifically need is a pic of the top of the fuse blocks which shows locations/wire colors and the legend that shows what the codes translate into wire colors. Thanks much!
Old 07-08-2016, 10:10 AM
Bone Doc's Avatar
Bone Doc
Bone Doc is offline
Received 10,868 Likes on 4,113 Posts
I can't help with the wiring diagram but I'll be the first to mention that a service manual would have the diagram you are needing. Do you have a service manual for your '01 Softail?
Hopefully someone will chime in with the information you need. Another option would be to stop in at a dealer. They may be able to get you the picture you need. Good luck.
Old 07-08-2016, 01:03 PM
Next In Line's Avatar
Next In Line
Next In Line is offline
If the bike starts in ACC mode, then remove the tank console and flip the connector for the ignition switch around.
Old 07-09-2016, 06:22 AM
Bender4's Avatar
Bender4
Bender4 is offline
Stage III
I do not have a service manual. I'm happy you brought that up as I will get one as long as it will have the wiring diagram in it. I did some digging on the internet and see there are lot's of different manuals out there so I was bit confused which one to get. Thanks
Old 07-10-2016, 03:36 PM
Bender4's Avatar
Bender4
Bender4 is offline
Stage III
Thanks Bone Doc and Next in Line, you were both right. I went to the local dealer who was really cool about letting me take some pics of the wiring diagram out of the service manual. I checked all the wiring in the fuse blocks to the wiring diagram, all was good. I then checked the wiring to the switch on the console, and noticed they did not match the diagram. For whatever reason, not sure if it was like this from the factory or not, I needed to flip the wires between the I and A. After that, seems to work like it should. Quite a mystery, but I sure learned a lot.
Old 07-10-2016, 04:24 PM
Bone Doc's Avatar
Bone Doc
Bone Doc is offline
I'm glad to help and happy you got it squared away. Ride safe.
Boog
Old 07-10-2016, 11:55 PM
Next In Line
There are 4 manuals in total from Harley Davidson:
Owner's manual - comes with a new bike, can be downloaded for free.
Service manual - what everybody suggests you get.
Parts manual - another must have because it shows the exploded view.
Electric diagnostic manual - when troubleshooting electrical gremlins.
Clymer and Haynes also make manuals but those are going to get you into more trouble than they are worth.
turbo38sfi
09-23-2020 10:12 PM
tlar1540
02-15-2013 10:26 AM
aloxdaddy99
09-30-2011 02:37 AM
Heritageman
06-19-2011 04:27 PM
Bavarian_Custom
09-11-2008 01:53 PM
Quick Reply: HELP! Need Wiring Diagram 2001 Heritage FLSTCI
