Help finding 12 volt accessory connector
Old 07-25-2016, 12:22 PM
dfwhockey17's Avatar
dfwhockey17
dfwhockey17 is offline
Any orange with white tracer wire is switched power, find one and tie into it, black is ground...
Old 07-26-2016, 05:34 AM
Axis39's Avatar
Axis39
Axis39 is offline
Originally Posted by j_bee
I think you're the winner!!!
That is exactly what I need!
For those telling me to just splice in, I've tried it in a couple places now.... Each time gives me an error code. So, I'm gonna try the 'Electrical Connection Upgrade Kit' the J Bee linked to above! Surprisingly, it's less than $20!
Old 07-26-2016, 05:36 AM
Axis39's Avatar
Axis39
Axis39 is offline
Originally Posted by Next In Line
Why don't you wire the passing lamps like the Heritage models? Just read the schematics to see how it is done properly.
I did try this. Again, it's because of these bulbs are not CanBus compatible... They throw codes when I try to connect them to any auxiliary or running light circuit.
Old 07-26-2016, 09:45 AM
Next In Line's Avatar
Next In Line
Next In Line is offline
I've never heard of "CanBus compatible" bulbs, sounds like a marketing scheme to make people spend more money.
Just get yourself an Elenco 1 Watt Resistor Substitution Box and put that between your bulb and wiring harness. Then experiment with the resistor values (starting at the smallest one and working your way up) until the codes stop. Once you find the proper resistor value, make a wiring harness using the proper resistors that fits between your light and wiring harness.
Axis39 (07-26-2016)
Old 07-26-2016, 08:37 PM
Zanthamos's Avatar
Zanthamos
Zanthamos is offline
I used the P&A fuse circuit from my fuse box to power my 12V Accessory power.
Old 07-30-2016, 03:29 PM
Axis39's Avatar
Axis39
Axis39 is offline
J_Bee had the answer! The electrical upgrade kit worked perfectly! The cool thing was, I had 15 and change left on a gift certificate... So, my total out of pocket, including tax was less than three bucks!
Now, my inexpensive and incredibly bright, with halo/angel eye bulbs are switched with my ignition.
The bulbs I used: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
timbo141
Electrical/Lighting/Alarm
11-29-2018 08:21 PM
wombat457
08-14-2015 03:43 PM
ADVNTR
2014-2023 Touring Models
04-21-2014 04:57 AM
Mr. Clean
05-17-2013 11:40 AM
jimski
08-02-2010 09:18 PM
Quick Reply: Help finding 12 volt accessory connector
