I keep hearing a tapping sound in my engine. It started the other day when I was in stop and go traffic and 96 degree weather. Thought it was probably an overheating issue. But then on my way back home after dark and at highway speeds it started again. Oil level is full. This is not the first time, as it has happened a couple of times before. Bike is an 08 fatboy with 18000 miles. Any ideas?
Does it sound like it's coming from the top end? Could be rocker shaft noise, and easily cured
__________________________________________________ ____ For ROCKOUT information & purchasing please click the LINKSbelow...
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
Good advice from Rockout, get some sort of rocker locking devices, get them from him, install them and see if your noise goes away! I can guarantee you it will quiet down the top end, even if this is not the exact noise you are hearing...
