rear wheels
Old Feb 2, 2017 | 03:12 PM
billytwobags's Avatar
billytwobags
Default rear wheels
how do i fit a fxstc 07 rear wheel to a fxsti 06 model rear wheel
Old Feb 2, 2017 | 03:32 PM
Scuba10jdl's Avatar
Scuba10jdl
Should swap directly because they both have 3/4" axles and the same size.
Old Feb 2, 2017 | 03:43 PM
billytwobags
Same axle thats it different pulley as the FXSTC has a larger pulley due to it being a six speed box . also the FXSTC pulley has a raised back on it . I think the rota had a spacer or packing like the deuce . I have put the wheel in and it does not align
Old Feb 2, 2017 | 04:09 PM
Scuba10jdl's Avatar
Scuba10jdl
The axle spacers are different, just need to put the proper length on in to align it. Need to use your pulley because of the teeth difference on the pulley and belt. Brake rotors are the same part.
The 2006 hub is actually a little bit wider, thus your spacing issues. You'll probably need pulley spacers to match.
Old Feb 4, 2017 | 03:55 PM
billytwobags
Default rear wheels
thanks for the replys
squarej
Aug 22, 2012 04:12 PM
bvette94
Apr 12, 2012 07:54 PM
Rynb15
EVO
Apr 10, 2012 12:14 PM
joebotics
Feb 27, 2012 09:29 AM
social2
Apr 18, 2007 02:25 AM
