Fatboy problem
Old Feb 8, 2017 | 04:37 PM
dillmanrandy's Avatar
dillmanrandy
Stage III
Angry Fatboy problem
I found a form For HD People,
So Thank You for this Webpage. I'm so glad to be here.
So if some one can help, me and my friend I'm going to talk to him to go on here.
He came over with his 2000 Fatboy FLSTF. It won't start, we looked at the spark plugs, and ignition coil, it ohm out good. We notice that his odometer will not light up or anything, we tried changing bulbs etc. We don't know what to do. We both don't have the money to take it to dealer. Can anyone help.
Old Feb 8, 2017 | 07:43 PM
FLS103's Avatar
FLS103
Check the contacts on the ignition switch.
Old Feb 8, 2017 | 08:37 PM
langwilliams's Avatar
langwilliams
is it a carb or efi bike? check the battery connections an the ignition switch. does it turn over?
Old Feb 8, 2017 | 08:44 PM
JesseDyna's Avatar
JesseDyna
Start with the battery and work forward. Fuses? How's the voltage on the batt?
The contacts on the batt can and will come loose.
How did he get it there?
Old Feb 8, 2017 | 08:48 PM
Snowyone's Avatar
Snowyone
Default book
Get the service manual. Make sure your battery is 12+; make sure it's getting juice through the main fuse; make sure the crank position sensor is reading the right voltage; cam position senser if it has one reads right; tip over sensor is functioning; ignition module is functioning. Good luck.
Old Feb 9, 2017 | 07:39 PM
Mr.Softy's Avatar
Mr.Softy
You say it won't start, does it attempt to turn over? More information would be helpful.
Old Feb 9, 2017 | 07:47 PM
RANGER73's Avatar
RANGER73
Like stated above, Need more info.
Kansasjase
25
Mar 27, 2020 07:20 PM
NomoreNomad
May 25, 2016 03:11 PM
Hrlyric
Aug 2, 2013 05:21 PM
Warrior23
Mar 30, 2012 05:11 PM
madmax1
Oct 7, 2006 09:30 AM
